BG air intake system cleaner Help
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Hello
First there is a guy on Ebay selling 2 each BG44k 2 ea BG airintake cleaner and2ea BG Fuel induction system cleaner for $40.00 shipped http://cgi.ebay.com/ebaymotors...IN_ITIt came priority mail
The instructions on the Airesol air intake cleaner says to spray 1/2 can into throttle bodies while the engine is running, When I remove the ducts from the throttle bodies my J30 will not start. Is there an alternate procedure, or a way to trick the ecu?
Where can I attach the hose to use the fuel injector rail cleaner( fuel induction cleaner ) ?I have a 1 qt stainless pressurized dispenser max 200 psi from another application which should work for this. It has a charge port for shop air a PSI regulator 0-110 and a flow controll valve.
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You are supposed to have a special fogger for the aerosol... so you can hook it inline and still have the intake hose hooked up.. I suppose you could get thec ar to at least start by unplugging the MAF
For the fuel thing youll hook it up to the fuel rail intake. Follow the hose that comes from the fuel filter and then hook it to that line on the fuel rail., Then ylull want to plug up the exit line so that it doesnt run back to the gas tank....
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Where did you get the pressurized dispensor? Do you work at a dealership or did you buy it off ebay? I am looking to get one of those for myself to do the same as you.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
mattd1979 wrote:Where did you get the pressurized dispensor? Do you work at a dealership or did you buy it off ebay? I am looking to get one of those for myself to do the same as you.
It is part #7054T9 at mcmaster.com modified with a flow control valve, on the outlet and a psi regulator and gauge on the air charge side. it was used for cleaning foam injection nozzles with a lacqer thinner. The tank is only $40 but I do not know about the regulator and gauges. I recovered it from a dumpster.
I spoke with the techs that made this and they say they put over $200 into it plus a couple of hours of machine shop time. No worth it to build your self
Modified by Gerardjg at 10:38 AM 4/10/2006
