BG-44K
NightRiderQ45
Car: 1998 Infiniti Q45
Hey. I have a quick question concerning this injector cleaner. Is this something that I can put in my gas tank myself like the usual o-t-c products you can buy from Autozone or do I have to get my car serviced with the product. I've have been using Lucas injector cleaner, but I just want to go ahead and use the best product. I found some on eBay for cheap and I am looking to purchase some. Thanks.
It pours right into the tank. Some more details on it if you search the forum.
Its suggested that you pour it into a near-empty tank, top it off, and go for a long highway drive (like, a couple hundred miles). Then, after that tank is depleted, have your oil changed.
92Q45guy
Car: 92 Q45 93,000 miles / chain guides / transmission cooler / synthetic fluids / lots of love!
That lucas stuff is pretty darn good. I use it also. Notice how it's a little thick. It's suppose to lube the valve guides, upper valve train, etc. I've used it on 10 of my other cars in the past with no problem.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
92Q45guy wrote:That lucas stuff is pretty darn good.
Read http://www.bobistheoilguy.com and you might change your mind.
No other injector cleaner that can be added to your gas tank is of the same strength as BG44K.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
BG44K is top notch. The only other products I've used other than BG44K are:
Redline Complete Fuel System Cleaner. I used this product with the first 2 tanks of gas when I bought the Q, right after the Pressurized Fuel Rail Flush:
I used to always use these 2 Liqui Moly/ Lubro Moly products on my German cars as a set:
Jectron - Fuel Injection Clean
Ventil Sauber - Valve Clean
92Q45guy
maxnix wrote:Read http://www.bobistheoilguy.com and you might change your mind.
O.K. I dont see anything about the lucas's fuel treatment stuff. I've used lucas oil stabilizer for a long time now with no problem. In fact, I purchased a 1989 350 pontiac firebird with 50,000 miles in 2001. I just sold it a year ago with 197,000 miles on it. Those motors are good for 100,000 not much more then that. Used lucas oil treatment in it every oil change. I raced the firebird every week at a local drag track, no problem. That gear contraption he had is nothing like a engine, maybe a gearbox but thats it.
Q45tech
Everybody has their own favorite SNAKE OIL and horse liniment.
Luckily most are designed to do little harm.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:Luckily most are designed to do little harm.
Unfortunately, not all are.
