Thanks I'll look through that thread and give it a try.jakenbake wrote:In the thread at the top of the forum where you are supposed to post pics, one of the members has some pics of upgraded sway bars. I would try sending him a message.
Nice, thanks for the info!!!j50ny wrote:Cusco makes them (front and rear) for the AWD platform. Those are the ones I'm going with.
roark187 wrote:This is incorrect. A typo. They only offer sways for 2wd. Hotchkis is the only awd kit for our cars. The benefit of swapping is more in the adjustability and rigidity of the bar itself than thickness. The EXs sways are pretty big already, maybe 2 mm smaller than the tuner brands, but swapping to adjustables with better end links will flatten our ride out a ton. Best bolt-on mod I've done for driving enjoyments sake.
Thanks, that would have been an expensive mistake if I had ordered them, appreciate it. Any suggestions of a supplier? Have any part numbers?roark187 wrote:This is incorrect. A typo. They only offer sways for 2wd. Hotchkis is the only awd kit for our cars. The benefit of swapping is more in the adjustability and rigidity of the bar itself than thickness. The EXs sways are pretty big already, maybe 2 mm smaller than the tuner brands, but swapping to adjustables with better end links will flatten our ride out a ton. Best bolt-on mod I've done for driving enjoyments sake.
already switched to 245/45/19's didn't help any as the body still roles a ton.AWGD8 wrote:As I mentioned from the other thread, I felt my EX35 has less roll or body lean when I changed the tires from 225/60/17 to 225/55/17 and the Goodyear RS-A tires seem to have a stiffer sidewall with the 55 series. Rims/tires came from my Q40 AWD.
I would say the Tower brace such as Cusco will not give you a night and day difference in handling.
Try experimenting with your tire pressure first (35PSI)then maybe a stiffer sidewall tire next...
BTW, my moms 2013 Toyota RAV Sports AWD has a stiffer suspension and ride compare to my 2008 EX35 AWD, even my 2015 Q40 AWD, I find the Ravy harsher.
wooooo, I'd love to see a review on the differences these cusco bars make.j50ny wrote:Cusco makes them.for the front and the rear. Not sure if that response earlier was in regards to the Cusco or a different brand. I am having them shipped to me direct from Japan. There was even a press release that came out a while back.
Definitely would not be an expensive mistake. Search for it...the AWD EX35 is the NJ50 body. RWD is the J50.
I am buying a handful of JDM parts for my build and have done extensive research on parts...most of which I'm buying from Japan.
