better flowing head on 95+ ka's
Bentleyness
Car: 92 240sx coupe
s13 front end
kyb struts
sportline springs
xxr 513 16x8-0 offset
Hello Nico buddies! btw im new just signed up and my first post! i feel awsome, and sorry if my vocabulary suck been in the hospital twice in 3 years for head injury(sports) so i forget to spell sometimes or switch words around so im sorry'
my name is Bentley yesmy real name in 22 and took 5 years to get my 92 240 coupe, i lost my gf because of my car, to much time into it lol and ill be getting a bike soon so no time for girls here just work and my joy, the right one will come
spent alot so much i could of bought a sr, but im just doing body work first and make it the way i want it to look.
mods:
xtd stage 3 clutch(works really good btw)
s13 front end
kyb struts sportlines
aiv/egr removed
5 lug needs to put on waiting fot funs for rims first
any how i was seaching around and i seached around and nothin so far.
http://wikicars.org/en/Nissan_240SX on here if u want to read it over but ill post a short part of it to show u wat it says.
this here:
For the model years of 1991-94 the KA24DE engine had cam durations of 240 intake, and 248 exhaust. In the model years of 1995-1998, the cam duration was reduced to 232 intake and exhaust. To compensate for reduced power, the intake manifold was made to flow more freely than the 91-94 model years, resulting in the same 155hp and 160ft. lbs as the 91-94 KA24DE
Read more: Nissan 240SX - Wikicars
Under Creative Commons License: Attribution
so would this mean that if i use 95+ intake manifold on my 92 i would have more flow? maybe a very small power gain?
i plan on doing the dual exhuast cams so the two put together would be cheap easy mods for under 200 or less/
155hp stock kade
if the 95+kade have the same power with better flowing intake mani and smaller cams
that would mean the 91-94 with bigger cams + 95+ intake mani=more power? maybe 5+hp?
any advice? options?
costa_rican13
Car: 1993 s13 coupe
this is true in a sense. or you could just remove your intake manifold, and remove the "butterfly flaps" that are in the inside, i think this is what they meant by better flow, they just removed the flaps. so no need to buy a new manifold. i did removal of the flaps in the process of removing my emissions. so do it all in one time, and you wont have to buy new gaskets and such when you remove all your emssions. :) hope this helped.
simmode1
Car: Red '95 S14
^^^Ditto...
93 Chuki FB
Car: 1989 240sx coupe, EMUSA coilovers, 1 piece drive line, welded diff, S14 KA24DE swap, 10lb flywheel, Modern rims with 10mm spacers, rear sub frame spacers, steering rack spacers.
I remember my friend swapped the top half of an S14 intake onto the bottom of his S13 intake and removed a bunch of emissions stuff also. I would get 4-1 headers, 248/248 cam swap, and a 255lph fuel pump upgrade. The fuel pump actually made a big difference. Me and another friend both have S14 engine's in our S13's, and mine (after the fuel pump upgrade) feels a lot faster and with a lot more pep compared to his. I remember one guy on here that did the 255lph fuel pump upgrade and he was saying how it was one of the best upgrades he had ever done on a KA. I only did it because im swapping to an SR and my stock pump died, so i just bought it to get it out of the way until my SR was done, turned out to be a good upgrade for the KA.
motoman399
Car: 98' wrecked (RHD coming soon) 240
yes there are gains to be had with the s14 upper intake. if i was you (or anyone with an s13 that wanted to remove the butterflys) i would not d!ck with the s13 manifold. the s14 ones are so cheap and you can find them anywhere.
Bentleyness
Car: 92 240sx coupe
s13 front end
kyb struts
sportline springs
chica chica waam! Sorry a superbad moment there
But I read on that s13 mani mod, not worth my time, but will keep looking for the intake mani here localy, u gotta love CL for parts and whores, jk about the last part, I'm looking into a rebuild right now and trying to keep it under 600, but I'm finding sr for under 1000k latley for complete swap,, idk wat I wanna do yet sr,kat,vh, So many but that's what I'm set on then again I almost got a free turbo 300zx motor darn, but thanks for the advice, tip,ex.
I guess I write delete so it get deleted? Idk I used to be in the rc airplane forums flying high speed jets, miss the good days when I used to do that,
Thanks and close thread
