Braincrampt »
https://forums.nicoclub.com/braincrampt-u107651.html
Sun Oct 05, 2008 9:49 am
Ok so I just got a 94 Pathfinder V6 5 speed manual trans here a few weeks ago and it ran great, untill the other day when I started to loose top end power in high gear. It would not rev above 2000 rpm, but was fine in lower gears. Then gradually it started to loose power thru the other gears as well, 4th then 3rd etc... Untill I was in 1st gear at 20 mph when it quit. No unusual noise from the engine or trans, no smoke out the back or smells... After having it towed home, we checked the usual suspect items, fuel... it has some and it is pumping out the filter when turned over with the hose off..we replaced the filter anyway. Spark, checked at the plug end of the wires doing just fine and the interior of the cap and rotor look to be in good condition. Having read some of the forums we checked and replaced the timing belt, it looked good but while we were in there we replaced it anyway. All sproket marks were in correct position when we pulled it apart. replaced the maf sensor, and still after all of this nothing! Turns over like a champ, has spark, has gas to the cylindars, timing is approximatly correct... but not even a sputter! Any of you real mechanics got any ideas??
