BRubble »
https://forums.nicoclub.com/brubble-u240123.html
Fri Jan 09, 2015 3:01 pm
Hey Dice,
With the '93 that I had, the Owner's Manual,, explained how to change the belt's.
The Service Manual,, will also explain how to change the Belt's. There may be a link here to download the service manual.
Online help is a good way to get advice,, but an Owner's Manual,, and a Service Manual,, are 2 thing's that a DIY Owner needs to have,, cause not all online advice is correct.
If the Nissan Service Manual isn't downloadable,, aftermarket SM's are available online, or at O'rielly's, Advance, Auto Zone,, etc.
I changed out the belt's on the '93 D21 4cyl, right before I sold it,, and on that motor,,it had Belt adjuster's that I just loosened up to take the belt's off. On the Alternator Belt,, I had to swing the Alternator in to get that belt off, after loosening the Belt Adjuster. To swing the alternator in,, I also had to loosen the Alternator Mounting Bolt, but don't forget to tighten it and recheck the belt tension,, as it may change after tightening the mounting bolt.
All above was on the ka24e 4cyl., so it'll probly be different on your 6 cyl.
Good Luck
