Postby
monkey5 »
https://forums.nicoclub.com/monkey5-u23411.htmlThu Jan 26, 2006 5:46 pm
whats the best size for handling?? i currently have 17x7.5 +35 all around, and i was wonder what is the best size with 225 tires in the front and 245 in the rear? i mainly use my car for grip driving?? and clues?? and yes this will be my track car. thanks for inputs.
Postby
naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.htmlThu Jan 26, 2006 5:56 pm
SEARCH!!!!!! By the way, you ask what the best wheel size is, but then start talking about tires. Makes no sense. Everything depends on how much power you are making, what suspension setup you have, etc, etc.
Postby
PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.htmlThu Jan 26, 2006 6:28 pm
as for best WHEEL size, there was a thread about this a year or so ago, and it was determined that 16" wheels were the best all around wheel, offering good grip, comfort, and low sidewall flex.
Postby
spider_slayer »
https://forums.nicoclub.com/spider-slayer-u20388.htmlThu Jan 26, 2006 6:37 pm
^^^ wheels mean nothing without good tires. the size is also not the determining fatcor. you have to take into account things such as size and weight. jsut search it makes everyones life so much simpler.
Postby
RPS13.5 »
https://forums.nicoclub.com/rps13-5-u39942.htmlWed May 24, 2006 10:29 am
How about if you upgrade into a 300ZX or R32 Calipers? This will affect the offset, and you might ended up using spacer's and ruined your offset...What is the best offset to get this big brakes fit. I only know so far is 16" wheel is the minimun clearance for this big brake, but I dont know about the offset?
