Bronze MFP wrote:if it doesn't spin when you blow into the turbine housing, it's junk. it should spin at least that freely and have minimal shaft play. You can't really look into the oil inlet/outlet to get a good idea of the condition of the bearings as they are out of sight. Of course if there is buildup at that point, its a bad sign anyways. good luck!
also, all the rb20/rb25/rb26 turbos are ball bearing
Wow, the blades should spin freely, but i dont know of many turbos that will spin by simply blowing on the turbine. It should spin freely with your fingers, should have minimal shaft play in/out, up/down....and shouldnt leak oil. The factory lines on most turbo cars tend to supply more oil than what is really needed.
