It's been sitting in the Phoenix heat for 3 years ... I parked it after the injectors started leaking badly and it was starting to run like cr*p. You don't ever want to leave your 240SX parked for that long ...
So here's what I've done ...
- Replaced fore and aft fuel filters- Replaced the frozen fuel pump- Verified that there is good gas flow to the fuel pressure regulator.- Installed 4 rebuilt Python fuel injectors.- Installed new battery.
She cranks over nice and fine ... I can hear the fuel pump working and there is healthy pressure when I removed the regulator to check it out, but the engine will not start. No gas seems to be getting past the regulator. Starting fluid will make it start for a second or two then it dies again (no gas!).
It seems like a simple device. It holds vacuum when I suck on that connection, but it sure seems like it would take a tremendous amount of vacuum for it to open (it seems completely closed if you try to blow thru the fuel intake).
Can someone please explain how it is supposed to work? If the vacuum line were off (or not working) would the fuel supply be shut off? Or should it still be open and passing fuel to the injectors before the engine is even turning? How is the vaccum supplied to it? It looks like the vacuum line goes to another electronic device on the back of the engine, apparently what is known as the Pressure Regulator Control Valve. Could the regulator be ok but the PRCV is bad and not allowing any vacuum?
Finally ... I have not done anything with the O2 sensor yet. If that were bad, could it keep the engine from starting?
What steps can I take to figure this out?
Thanks!
Brad
