Best way to swap out the motor?
ZOMG.SR20
Car: 1990 s13
im in the process of swapping out my block and head should i pull just the head and block while un bolting the transmission or pull it all out and swap it over which way would be easiest i can do eithier i just want people's opinions on what they have done.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
i would imagine taking out the transmission along with the engine would make life a lot easier in the long run.
S13Joe
Car: 92 Coupe
I just use grenades whenever i run into this problem.
Nah kidding, yeah pull that transmission with it. Pulling the transmission alone sucks.
Just did 2 seconds of searching for ya too,http://www.ttzd.com/tech/enginetech.html
vangj
Car: Cars, Sports
I would probably suggest pulling the motor and transmission out together as well. From experience with doing a SR swap before, it's pretty easy to pull ou the motor and transmission together. Seeing where the transmission bolts are, it'll probably be hard to reach the bolts to get enough torque to unbolt it. Just my thoughts.
rob912
Car: 91 240 rb20
option B is way easier
Justin35ll
Car: s13 coupe sr20det
I would pull the transmission with the engine and swap the transmission on the new engine and swap it back in, that's your best bet
Chris28
Car: 92 s13 KA-T
Please for the love of god take the transmission out with the engine. It comes out easily it's a lot easier than getting to all those bellhousing bolts right at the firewall.
Plus trying to put the engine back on the drive spline of the transmission is ridiculously hard when both are "in" the car.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
ZOMG.SR20
Car: 1990 s13
thank you option B it is then
574-240sx
Car: Nissans, Toyotas, Subaru
I pulled a motor out last night, disconnected the exhaust manifold, trans, powersteering pump, a/c compressor, in about 2.5 hours and it started sleeting while in the middle of it in my driveway. If you are just swapping out long blocks this is the easiest way to go.
