You still can go LS
Really depends though AZ. I hooked a buddy up with a block, heads, wiring, and ECU and he got his motor all together for about 1000 (honing/cleaning, Pistons, New Rings, Rods and Crank w/ all bearings) and got a tranny for 1100 (ended up being a built trans) I cant find the motor sets for much less than 2500 unless you come across a deal.
The 6.0 seems to be the best bang for your buck though. Engine can be found from 400-600 in junk yards /ECU and harness. L76 intake, L92 heads and cam setups are making over 400 close to 500 whp with 1100 in heads, 300 for injectors and 300 in cam. So theoretically 2300 for motor give or take a few hundred and 1000 give or take a few hundred for trans you could have a pretty nice setup.
