Best way to sit lower in S13?
Ter171
Car: SR20DET 240sx Hatch
I was wondering if aftermarket seat brackets/rails would fit on OEM s13 or s14 seats to help me sit lower, because when I wear a helmet, it hits the roof, (I have a long torso). I don't want to get a low sitting racing seat like Bride Low Max just yet because of the $$$ factor and it's my daily driver so I want something comfortable still. But if that is my only option....
HELP! Planning on going to events in March.
patrickm1587
Car: 1990 240sx- SR20 swap and a turbo that's absolutely too big, spools around 4,400 and I love it!!!
Why don't you just take the stock seats out and see if you can cut the stock brackets and make it sit a couple inches lower? Do you have a welder? You could easily do it yourself if you did.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Hahaha ... I thought this was gonna be about lowering the CAR, that is until I read inside! :chuckle: Anyway, maybe a cheap fix is to lean the seat back and pull it forward a bit? Although, I know that may not work for your ideal driving position ... just a thought. Is your headliner removed already?
Ter171
Patrick- Have you seen anyone do that before? Also from what I remember, the design of the brackets just doesn't have a lot of room for cutting. All I need is to go about 1 inch lower...
Scotty- Lean back thing won't work for proper driving position haha And headliner won't do anything because I have an aftermarket sunroof, and it's that sunroof's bracket that is what's getting in the way =(
HAWAII
Car: none
get a low cost bucket and rails then take the cushions off when you are driving in an event
PEZi
you can always bottom mount it :gotme
scotty-2-forty
HAWAII wrote:get a low cost bucket and rails then take the cushions off when you are driving in an event
I thought about that too ... my Kirky race seat was not expensive at all, sits lower than the stock seat, you could modify some universal seat rails (or fabricate), and also remove some material from the seat cushion bottom, or remove it altogether come race day.
240sxRturbo
Car: 1991 240sx lx 10:1 compresion
i have used tenzo r seats on low profile rails before and i sat higher than stock i hated it just warning u u need to get a side mount rail for ur seat i think u can get them grom buddyclub sometimes they get a little $$$$ but its deff worth it i had some in my old 240 loved it
