480sx wrote:Camshafts connected to tha... Timing chain! Timing chains connected to the.. Idler sprocket! Idler Sprockets connected to the.. Lower timing chain! Lower timing chains connected to the.. Crank shaft! Oh, and the head studs are directly under the camshafts too....
Sounds like somebody either got up too early or stayed up too late.
irichjohn Judgeing by the questions you are asking I would guess that you have limited experiance. Either get a good friend that has experiance to teach you or take your car to a shop. I am all for do it yourself but removeing cams and heads are not for rookies.
