Best way to purchase full Megan Exhaust?
steelcity
Car: 2007 Infiniti M35x
Down pipes, Y-Pipe and Catback. Am I forgetting anything?
Also, does anyone here have headers?
Larz
Car: 2019 Q70-L RWD
Most places that 'say' they have the Megan in stock .... don't. They take your money and leave you waiting while they wait on a back order. I suggest you PM Freddy (MY06M45S). He is the best source for all things Megan. He can find out if there are any available, give you a price, and get it to your house.
steelcity
Wow no sh1t? Thanks Larz. That would've been alot of unnecessary stress. I'll shoot him a pm. As far as the headers? Would they help or hurt the car? I dont know much about back pressure. Would the car lose too much air/power? Is DC the only header?
FlawleZ
Car: 1992 Nissan 300ZX TT
1987 Nissan 300ZX Turbo
2017 Nissan Titan SV 4x4
I'm assuming M35? Headers are of course helpful and with a good tune you can see good gains in the midrange and top end of the rpm range. The back pressure should be controlled with the exhaust setup. It's important to leave the cats in place if your concerned about back pressure.
Blackzilla
Car: 2007 Infiniti M45, 2014 Mazda 6
just PM'ed Freddy about it thanks Larz
Blackzilla
and FlawleZ are headers only made for the M35? looked on Motordyne and the M45 isnt even listed
Wangtang408
Car: 2006 Infiniti M35
Blackzilla wrote:and FlawleZ are headers only made for the M35? looked on Motordyne and the M45 isnt even listed
Only for M35 for M45 will need to be custom.
Look up on the Titan forum, member Dean45 was in the process of making it, search up his thread.
Blackzilla
awesome thanks for the response
Wangtang408
Blackzilla wrote:awesome thanks for the response
Mybad, I meant to say member Dean45 on this forum on his header build.
But you can look up the Guys on Titan forum for headers.
Wangtang408
steelcity
FlawleZ wrote:I'm assuming M35? Headers are of course helpful and with a good tune you can see good gains in the midrange and top end of the rpm range. The back pressure should be controlled with the exhaust setup. It's important to leave the cats in place if your concerned about back pressure.
I know long tube headers are more for top end, shorter are for shorter distances (that's what I prefer). What's the best set-up to use if you want headers as well? Is the full Megan and headers ok? or will you lose power? The cats would stay on if you did the full Megan right?
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
I wouldn't mess with headers... just get the following mods if you're looking for usable performance:
1.Intake performance
Z Tube
5/16 plenum spacer
MREV2 (modified lower intake manifold) and Armid gasket
2. Exhaust performance
HFC's (get new or used that fit from G35's (VQDE motors)
Ypipe (since you have an X model, you may be limited but Megan makes one)
Mid-pipe
axle backs
3. UpRev Tune
4. lose weight on your car.....
When I was living in CA, I'd get my Megan exhaust parts directly from Megan...my buddy's shop is a few blocks from Megan and he and the owner are longtime friends....I posted this awhile back..
steelcity
CPJ LB wrote:I wouldn't mess with headers... just get the following mods if you're looking for usable performance:
Z Tube
5/16 plenum spacer
Mid-pipe
axle backs
3. UpRev Tune
Thanks for breaking down a good set-up @CPJ LB.
I do already have an Injen Intake, Lightweight Unorthodox Crank Pulley and the 5/16 Plenum Spacer. I wish I had known of the MREV2 before I installed the plenum spacer. Too much work to take that off now and re-do it (dam!! that's 15-20 HP right there too!!). So really for me it's the exhaust and tune that's left.
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^ no prob!! If you change your mind about the MREV2, I suggest getting a used one off of the G35 Forums - a lot cheaper!!
Another thing that I did with my M (and now with my G37X) is removed the spare tire in the trunk and placed a piece of MDF board (thin) underneath the cargo liner/board to provide support for the weight of groceries, luggage, etc...I think that spare tire weighed over 40lbs..? and when you swap out your exhaust system, it'll help reduce weight as well..... good luck and have fun modding!!
Blackzilla
too bad i have an M45 so i think i'm stuck with just intake, exhaust and UpRev. i got the R2C intake and I am waiting on a Megan axle back (fingers crossed that the wife will buy the mid pipe)
steelcity
CPJ LB wrote:^ no prob!! If you change your mind about the MREV2, I suggest getting a used one off of the G35 Forums - a lot cheaper!!
Good to know for the MREV2. Have you ever dyno'd your car? or track? Im curious what the quarter mile is with all these mods and uprev tune.
Blackzilla
just put in the Megan axle back yesterday and it sounds good. can't wait to get the midpipe for it. ordered from THMotorsports and i want to thank MY06M45S he saved me a bunch of money!
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
I've posted a lot of my mods here a few years back... Yes, I've dyno'd my car when I would get a tune or updated tune...The best that the car recorded was 291whp (approx 350hp at the crank)... I've done an 'unofficial' 0-60 run approx 5.3 seconds (good launch). I haven't gone to a track to run the quarter mile though.
I've done some videos that you can check out for the sound of my exhaust set up I had a few years ago... search on Youtube: "M35 Sport Megan"
steelcity
5.3 is not bad at all.
I was on the motordyne website and it says that the MREV2 combined with the spacer is about 20 HP. Spacer alone I think is pulling 12-15 HP.
I just want to see what else can be done before I do the tune. Exhaust is next though.
BTW: what's HFC's? high flow cats?
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^correct, HFC's = hi flow cats...
Motordyne makes their version of test pipes called ART pipes if you really want to add more power... keep in mind, test pipes will produce more exhaust fumes than HFC's.
With your car being an X model, I don't think Motordyne makes their ypipe (called xyz pipe) for the X... that was a mod that I had on my car...very nice ypipe with interchangeable sections (resonator, HFC, or straight pipe)....
steelcity
Z Tube
5/16 plenum spacer
Mid-pipe
axle backs
3. UpRev Tune
I'm having a hard time getting the Megan exhaust. I can't find anything! I contacted Freddy a few weeks back but he hasn't gotten back to me yet. What should I do? How much is the Megan cat-back compared to the Stillen catback (which is going for $980 on their website).
Blackzilla
try THMotorsports.com they were really good when I ordered the Megan axle back
steelcity
Blackzilla wrote:try THMotorsports.com they were really good when I ordered the Megan axle back
I checked them out blackzilla. I had seen your thread and went to their site to see if they had it, but all they had was the axle back. The thing is, I just want to order it and be done. I dont want to do this part now and then a month later do another and another. Just want to slap it on and get it over with.
Blackzilla
ah so did they not have the mid pipe and the axle back in stock? or is there more that you wanted? and you mightve done this but have you called Megan to see if they have any in stock at all because from what THMotorsports told me is that you order from them but it gets shipped straight from Megan
steelcity
To be honest. I havent called Megan. For the AWD model we need the Y-pipe and cat back right? Is the cat back the mid pipes and axle back? and I was told to get HFC's.
Blackzilla
I know cat back is mid pipes and axle back so I know Megan has that for you but honestly I don't know much about the difference with the X models. hopefully someone with an X can fill in
steelcity
If I get the Stillen catback, I can always get the Megan Y-Pipe right?
steelcity
Hey Blackzilla, I was wrong. I did find the axle back and mid-pipes from THMotorsports. So finally! Placed the order.
The only thing I need now is some help getting a Y-Pipe and HFC's. The HFC's are expensive on Ebay!
TOMatBMR
Car: 2006 M45 Sport
Hopefully you get the product. THMotorsport has a terrible reputation in the aftermarket parts industry and not just for not having products in stock but they are notorious for violating MAP policy and pricing agreements and are blacklisted with many product manufacturers because they don't play by the rules so to speak. Many companies will not stand behind the warranty on the product if purchased through them as well.
Blackzilla
nice steelcity! TOMatBMR I ordered from them and received the product in about 6 days if that. as for the warranty I sent in my warranty paperwork to Megan headquarters and it came back undeliverable so I have no say with that. but THMotorsports pricing was good vs others so I am completely satisfied with them. I hope you have the same success steelcity
