In theory, that approach should work. Definitely, as you go lower the stiffness increases and you can compensate for that by decreasing the dampening. But if you go really low and drive across dips or bumps, and have a soft dampening setting, you could run into rubbing issues from suspension travel.Jlor1002 wrote: My issue is I've read that springs offer a better ride than coils for daily driving - I don't understand how this is possible. Why can't you just adjust the coils to find the ideal ride height and stiffness? Couldn't I just drop my car 1in to 1.5in and soften the damping to accommodate for bad roads? Or are springs the way to go?
The more your lower the car, the stiffer the springs will typically be to prevent it from bottoming out. To compensate for stiffer springs you need STIFFER damping, not softer. The amount of damping needed increases proportionally with the square root of spring stiffness (wiki 'damping' if you're interested). If you don't increase it, the car will oscillate and have a terrible ride. The manufacturer of the coils should be able to provide data, something like this:AlexM. wrote:In theory, that approach should work. Definitely, as you go lower the stiffness increases and you can compensate for that by decreasing the dampening. But if you go really low and drive across dips or bumps, and have a soft dampening setting, you could run into rubbing issues from suspension travel.Jlor1002 wrote: My issue is I've read that springs offer a better ride than coils for daily driving - I don't understand how this is possible. Why can't you just adjust the coils to find the ideal ride height and stiffness? Couldn't I just drop my car 1in to 1.5in and soften the damping to accommodate for bad roads? Or are springs the way to go?
From my experience with BC's, I couldn't find the perfect dampening to get a smooth ride and I don't think its possible =/
I think with a 1-1.5 inch drop I used 5 clicks in the front and 10 in the rear and it. I also tried something like 12 and 20 suggested by Loop and that was comfortable also. But still not smooth by my standards.
But there's no way to tell exactly find out if " a x drop and a dampening setting of y" will give you a smooth ride or not. It could, or it could be stiff still. Even at this "perfect" setting, I bet springs would still be smoother. Coils aren't meant for daily driving anyway.
But yeah get Tein!
I second that.SanoSuKe wrote:andy you know your s*** dude lol.
andyhenault wrote: The more your lower the car, the stiffer the springs will typically be to prevent it from bottoming out. To compensate for stiffer springs you need STIFFER damping, not softer. The amount of damping needed increases proportionally with the square root of spring stiffness (wiki 'damping' if you're interested). If you don't increase it, the car will oscillate and have a terrible ride. The manufacturer of the coils should be able to provide data, something like this:
http://home.comcast.net/~ralphws1/images/usstock.jpg
My suggestion to have a low ride and still something comfortable would be to find a custom spring manufacturer and get a non-linear spring that is soft at first, then much much stiffer at the end of the stroke to prevent bottoming out. This would be a b**** to do, but it's really the only way to have the best of both worlds. Ride comfort is the reason our cars have such a huge wheel gap.
on the surface. But after reading it on wiki, it makes a lot of sense. So spring stiffness and spring damping are not the same type of stiffness, right? Or actually, it seems they might both be the same stiffness but just act in opposite directions.andyhenault wrote: "To compensate for stiffer springs you need STIFFER damping, not softer,"
I know a fair bit about suspension engineering, glad to help anyone with Qs.SanoSuKe wrote:andy you know your s*** dude lol. my official adviser from now on. xD
[/img]
. I have been super busy with work and trying to keep my dog exercised and stop from bouncing off the walls lol. So will update new photos with my good camera soon!!
