Kansei240sx wrote:Darius, you can take out the factory gauge cluster plugin that is for the temp sensor, it doesnt run to the ecu just to the body harness/gauge cluster, you must be thinking of the CHTS ( Cylinder Head Temperature Sensor ) is the one that runs to the ECU and will run rich if unplugged. I just put a temp sensor in my greddy intake manifold where the stocker goes and it work perfectly and i dont run rich. ~12.3 afr
I think you misread Darius' post. He said the same thing you just said.
There is a coolant temperature sensor for the ecu, which is always required. There is another coolant temperature sensor, single wire, for the gauge cluster.
Darius' was saying that you could remove the gauge cluster sensor and replace it with a sensor for a different gauge if you wanted. But if you did this, you would obviously lose the coolant temp sensor in the gauge cluster.
Cpt_Impossible wrote:So, is the RB20DET coolant hose the same diameter as the stock KA hose? I am assuming so because the radiators are interchangeable, you use the ka koyo...
I need to be sure before I order a sender adapter that the inner diameter is the same as the 240sx.
http://www.nissport.com/catalo...tions
The coolant hose is the same diameter as the KA. So you can get one of those adapater for a KA and it should work for you. Just make sure that the thread pitch of the adapter fits the new sensor's thread pitch. Some are 1/8" BSPT while others are 1/8" NPT.
