Best way to get rid of Carbon Build up.
KACOUPE92
Car: 1992 240sx
Alright so I have 219K miles on my 92 Coupe complete stock. Compression readings are 160 160 150 160, So pretty damn good. Car runs fine but the car puffs out a little bit of blue smoke. Car does not overheat, Runs good but just a little puff of smoke. I was told to run 108 unleaded octane and drive down the freeway at about 4k RPM and let that burn it all out. Would that help any? or is their better ways to flush out carbon build up. Thanks.
AZ89two4Tsx
Shell gasoline lol. But really, take a long road trip. That tends to help.
KACOUPE92
Car: 1992 240sx
AZ89two4Tsx wrote:Shell gasoline lol. But really, take a long road trip. That tends to help.
I use QT Gas... is it better to run 91 in a KA? Also should i add in some oil additive?
pitchlock
Car: 90 240sx fastback (rip 3/25/08) and
1993 fastback trackcar
1991 coupe (wife's car)
1974 datsun 260z
I diverted my pcv hose through a catch can before It goes back into the system. Its helped alot
AZ89two4Tsx
I was joking about the gas. But a LONG road trip at highway speeds will help.
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
Running 108 octane sounds about like running some fuel injection cleaner. One brand has on the bottle with jet fuel. Just run some cleaner through it and go drive on the highway at a high rate of speed it will clean things out.
91240se
Car: 94 Mazda Mx-6
if you really want to clean it up as well as some grime in the motor run some seafoam some people say mixed reviews about it but it works. Sometimes a little bit to good (eats bad seals). If you wanna go a little bit easier get some lucas fuel injector cleaner and run like 2-3 cycles of that and you should be good to go from there
Cone Junky
Car: S13 fastback
BMW e46 328i
I highly doubt the blue smoke has anything to do with carbon build up. In fact, a high carbon build up would create higher compression. Blue smoke is oil, so I would be looking at rings and valve stem seals as a more likely culprit.
But if you realy want to clean the intake system, SeaFoam is as good as any other product. Combine that with the regular use of Chevron Supreme with Techron and that will manage any carbon build up you may have.
Cone Junky
Car: S13 fastback
BMW e46 328i
I like your avatar. Is that all the money we can be saving if we owned a Honda?
maximaRIP
Car: maximaRIP 240sx 1976 chevy van
Thread jack....no that the money you can be taking when you beat honda...
But on a serious note I have use penzzoil high milage(10w 40w with 200,800 milage) and my oil leak is almost none exsistanting, and that after I use a gtx stuff which suck I don't recommend with a bottle of lucus it still smoke....
