best way to flush coolant system?
mmashburn
Car: 1992 240sx
when i got the front clip, i drained the coolant out of the stock sr radiator, it was really murkey and dirty... whats the best way to clean out the whole entire system?? can you do anything w/ a garden hose and just run constant water through it until everything is flushed through?
karmakaze
Car: 98 240sx SE
i usually just use the water hose.
mmashburn
Car: 1992 240sx
whats the best way to avoid getting air in the system?? also what is the purpose of the little air pressure release screw that is on coolant elbow near the thermostat?
DawgMode
Car: 180sx
thats how u get the air out through that screw
Hijacker
Car: '92 240sx Convertible
'94 F-150
mmashburn wrote:whats the best way to avoid getting air in the system?? also what is the purpose of the little air pressure release screw that is on coolant elbow near the thermostat?
when you're filling the system, unscrew that bolt and fill the radiator until you see fluid start to leak out of that hole. Then replace the bolt, fill the radiator up all the way, and turn the car on. once the car reaches operating temperature, the thermostat will open up, and you can finish filling in the radiator if the level drops any.
