best way to drain gas?
loudbay
Car: duh
hey just wondering what the best way to empty the fuel tank would be.... thanks for any input....
[s3]
siphon it out
KSee777
The fastest is to stick a lit match in it.
Ok, I'll stop post whoring... But like [s3] said, siphon it out into a portable gas tank. ie those plastic red ones MADE for carrying gas. They come in all differnt sizes. Just don't put gas in ANY TYPE of plasic container.... it WILL eat through it.
loudbay
Car: duh
i figured siphoning would be one way, but i was looking for a better way, besides dropping the tank, or getting a mouthful of gas. i should make a dentist appointment, and have gas breath when i go..... if you guys get any other good ideas, let me know,.
Nathan
Use a clear tube, then you know when to stop sucking on it :)
loudbay
Car: duh
very good idea.
book-ends
Car: ???? Nissan 240SX coupe S13
Don't the 240's have a gas tank drain hole by the rear suspension sub frame, or am I thinking of my girlfriend's Focus? Sorry, I don't have my FSM with me, but I thought for sure that it had a drain on it.......
loudbay
Car: duh
i am 99 percent sure they don't have aplug... at least i can't find it...
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
You could always calculate your exact gas mileage and drive til you're just running out as you pull into your driveway. Slightly more complicated but no risk of gas-in-the-mouth :D
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
Let the fuel pump pump it out for you.
Disconnect the fuel line in the engine compartment before or after the filter. I dont know if the fuel pump is always active when the key is in the on position, but if it wont stay on, disconnect the harness for the pump and apply 12v. Stop the pump immediately after fuel stops coming out, or you could overheat and kill your pump.
Dont all cars nowadays have some sort of antisiphoning device in the filler neck?
My FSM make no mention of a drain plug.
Nathan
leper421 wrote:Let the fuel pump pump it out for you.
Using that stuff called intelligence I see. Well we'll have none of that! On a positive note, gasoline doesn't have much of a flavor. Neither does motor oil in case you were wondering :)
Trppen37
Car: CA18DET
ive tasted diesel fuel...it leave an oily residue in ur mouth..
Squirrel
The fuel pump thing is pure genius, I'd never thought of that one.
Squirrel
Oh yeah you can also buy siphons with a squeeze bulb to suck the gas for you.
loudbay
Car: duh
thanks alot guys, i bought the car with a cracked ka head, and now with all my new sr goodies, i don't even want to start it with this old gas. i think that using the fuel pump will work good, i'll jack up the front, and keep turning the key from off to on (i think it runs for a few seconds). i got a supra tt pump so it should go pretty quick. thanks again.
loudbay
Car: duh
and yes it does have some sort of anti siphoning device....
Trppen37
Car: CA18DET
loudbay wrote: i got a supra tt pump so it should go pretty quick. thanks again.
the thing fits in out tanks?? why dont u sell that fuel pump to an mr2'er and buy a walbro 255?? not only u would u save money for like a manual boost controller u also would have a nice high flowing fuel pump..
KSee777
Nathan wrote:Using that stuff called intelligence I see. Well we'll have none of that! On a positive note, gasoline doesn't have much of a flavor. Neither does motor oil in case you were wondering :)
Trppen37 wrote:ive tasted diesel fuel...it leave an oily residue in ur mouth..
Wow... who would have known... some people DO have gas for brains.
oakleys_s13
Car: racing drifting and parting
hey yo the easy way to do it is to undo your fuel lines and jump out your fuel pump relay and pump it all out that way or at least that is what i did
loudbay
Car: duh
Trppen37 wrote:the thing fits in out tanks?? why dont u sell that fuel pump to an mr2'er and buy a walbro 255?? not only u would u save money for like a manual boost controller u also would have a nice high flowing fuel pump..
the supra tt pump (denso=quality) flows 290lph at 12 volts.... so hold on to your walaby or whatever it is..... and i've got an avc-r so you can keep your boost controller too....
