evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Feb 12, 2018 9:46 am
Here is what I do, plenty of variations on your preferences and tools at hand.
Start with a dry warm engine bay and an assortment of scrub brushes and a shop vac. Scrub all the surfaces you can wiht brushes while vacuuming up any loosened debris. Next spray everything down with your choice of degreaser, there are engine specific products, I usually use purple power or similar, again brush everything you can to loosen up any stuck gunk. next comes the pressure washer, this requires a bit more finesse than a hose, if you only have a hose you can be more liberal as you spray, I try to focus the stream on the sheetmetal of the engine bay and or any dirty areas, wiht the pressure washer you must not get too close on things like bents, hoses and electrical connectors, there are plenty of hard surfaces to focus the stream on and plenty of overspray to rinse those more delicate areas.once dry, liberally spray any hoses or hard plastic bits with your choice of vinyl and rubber protectant spray, let it soak for at least an hour, overnite is better.
