Yeah, seen it but never heard if it´s a good piece. I´ll try to find more info.capwred wrote:you can now get the lm-1 in a round gauge.
i have a freind that got that new one from afx i think thats it.he got it off of sparkplugs.comand it works fine.
Damn... I just checked AEM on e-bay, best prices. Also looked at Zeiztronic (sp?) but never heard of it. Dynojet also had a nice on.capwred wrote:all i have read about the aem is that there not that correct.i have two freinds with them one on a g35 and the other 350z.they like them but both of them was of from the dyno.but that might have been the dyno.
Agree about the dyno widebands. I read your post to fast, then I´ll buy the AEM. Do you have any more coupon´s in store?c-rad wrote:I have an AEM wideband. I trust it more than I do the dyno sniffer. Dyno widebands see a lot of use (and many with leaded gas) therefore I don't trust them at all. I got my AEM for $225 shipped off ebay (with my $25 off coupon).
That´s the most pornish one. Looks really good.GoofyATX240 wrote:I love the plx its accurate and to the point. It isn't too expensive, but I really want the zietronix one.
Here is the Zie link http://www.zeitronix.com/Products/zt2/zt2.htm
a good tuner SHOULD change his sensor pretty often. plus the unit they use is most liekly more acurate then the AEM, the aem has been known to read off, plus ur technically not supposed to always run a wideband due to the fact that the sensor wears out much quicker, tho i know i would run one if i had one all the time to monitor af. but yea, from my research the aem has been known to read offc-rad wrote:I have an AEM wideband. I trust it more than I do the dyno sniffer. Dyno widebands see a lot of use (and many with leaded gas) therefore I don't trust them at all. I got my AEM for $225 shipped off ebay (with my $25 off coupon).
Most of the brands use Bosch sensors and 160 hours is for tuning. The cars normally run VERY rich for a while under tuning and the sensor get clogged (sp?).And besides that, crazy temps that make the life shorter of the sensor.UMS_CA18DET wrote:I dont know 160 hours seems kind of bull**** dont forget a lot of cars have Wideband O2 sensors and they are on lifetime. If those WB sensors fail in 160hours than go with a Bosch as those are the ones that are used in Hondas, Volkswagens etc etc.
I agree... the HX Civic from the '80s uses a wideband (the one used in the DIY wideband kit) and I highly doubt it had to be replaced that often. And that is a Bosch sensor. Its true that heat will kill it, and thats also why they tell you to install it 36" away from the turbo in a turbocharged car. I put mine in the downpipe right before the flange to the catback.UMS_CA18DET wrote:I dont know 160 hours seems kind of bull**** dont forget a lot of cars have Wideband O2 sensors and they are on lifetime. If those WB sensors fail in 160hours than go with a Bosch as those are the ones that are used in Hondas, Volkswagens etc etc.
