Best turbo Size for SR20DET
JDM240sx
Whats the best size turbo for the SR if you wanna be in the 500rwhp range? Im not too familiar with the SR. Sorry. Im used to the 2JZ's and 13B's :)This is my first Nissan venture :)
SpeedRacer1
Car: 1990 240SX, G35
To put up those numbers you'll be running a big turbo with alot of lag. Do you have a particular company in mind?
JDM240sx
I was thinkin a Garrett T04S via a custom kit thru XS-Engineering. It all about the prices right now. I also did notice that Blitz make a nice kit that includes a manifold and wastegate, but I have no specs on their K3T turbo. But im sure that crazy $$$ as well. Right now Im just weighing my options and laying out a few scenarios. Turbo Lag is something Im not too worried about as yet. I know someone running a T-70 and their at full boost (19psi) at 3700RPMs. if a T-70 can be fully boosted at 3700 Im sure a smaller T04s can be at full boost sooner than 3700 with the right setup.
SWIFT_DRIFT
are you going to do anything about the sr's internals so it can handle the hp you want?
JDM240sx
IF i am boosting past 15 psi. I will certainly get metal head gasket, forged pistons and rods and ACL bearings. But I am uncertain about valvetrain. Does that need to be beefed up as well? or can I get away with stock valves and springs etc?
Nismo_Freak
Car: 89 Nissan 240SX
I would run a HKS 3240 turbo... twin ball bearing turbo capable of 30 more HP than the T04S and given the A/R and trim it will spool earlier too.
Nismo_Freak
Forgot to add... I would upgrade to a lifter failsafe brace, titanium retainers, forged or titanium springs, and new cams will help flow and can help to spool the turbo.
SWIFT_DRIFT
you can get the hks 3037S with the same trim and a/r as the 3240.
