[quote=" Dori Dori Honestly, I think you just have a hard time taking criticism... you're probably an engineer or something so it's like a straight shot to the nutts when anyone opposes your ideas. [/quote]Hah - well I am an engineer. It just appears to me that you dismiss any ideas with a sarcastic smilie, which is smug in my book. But oh well.
Quote »Oh, and according to this page (
http://www.awe-tuning.com/page...AQ=22 ), load application is adjustable on their dyno and a Dynojet to lessen the load at the wheels, effectively lowering inertia, right?
As for your curiosity about a GT28rs w/ a .64a/r, don't bother because AFAIK, they don't exist.[/quote]
The dyno you linked to is a Mustang dyno that uses hydraulics to steplessly vary resistance. There is no inertial forces involved(well, they are negligible). The only way to change load on a Dynojet is to change the gear the run is done in or change the rollers out to heavier/larger ones.
The 0.64 A/R turbine option is listed on the GT28RS page of the Garrett catalog, it's just that most places(including SCC) use the 0.86 A/R. Here is a link where you can DL the catalog:
http://www.turbobygarrett.com/...s.jsp
Also interesting is that the corrected turbine flow for the 0.64 vs. the 0.86 is only about 1-1.5 lbs/min less at any pressure ratio the manifold will be likely to see. Shouldn't pose a huge restriction in flow, but spool up even quicker. The 0.86 A/R housing probably isn't all that stressed by the time the T04B compressor gives up the ghost. 0.64 A/R looks like the better match to me, but I do tend to always arrive at turbos that have a slightly higher stressed turbine than compressor.
The FP Big28 looks sweet, but is it just me or has that turbo already fallen flat on its face after 6k RPM? It'd probably be making only around 150 ft-lbs of torque at 7.5k, which is pretty weak. I guess there's no getting around breathing through that tiny T25 back end.
