best transmission fluid for a 91 KA24DE-T
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
like the topic says.
whats the best so far that can cause less grinds
rps13srsc
Car: 96 240SX Base Model
red line mt90
480sx
Car: 1996 Pearl White 240sx
AMSOIL 75-90 gl4
Its a true GL4, a lot of the fluids out there now are gl4/gl5. Id rather stick with something thats specifically intended for my car.
240sxvaj
nico! anymore answer for my question?
bruinbear714
Another vote for Redline MT90!
rps13srsc
we have used mt 90 and goten rid of all grinds in some trannys
BoostFab
Car: S13cp, S13fb, S14z
you can also use the Pennzoil Synchromesh; it's good with getting rid of the grinding, and you can get it at your local parts store. it's the same stuff as GM Synchromesh which sells alot more.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
bruinbear714 wrote:Another vote for Redline MT90!
+1...my second gear grinded pretty bad and third gear was a little better but was still rough. A week after switching to the mt-90 they are all gone. That was 20K ago and the transmission still shifts good.
Redline
Daily Driven 240
Car: s-13
i used Royal Purple Synchromax in my transmission, my second gear was grinding and after putting that fluid in it went away completely. so just an other option for you guys out there.
mach5camaross
Car: 90 240sx hatch KA24de-t
either redline MT90
or
Penzoil Synchromesh
Any real gear lube is better then running your standard 75w-90 oil.
WDRacing
I have lways supported Lucas Oil. They sponsor a lot of racers and had a kickass booth at SEMA. Good people as a whole IMO.
Redline would be my #2.
WD
240sxvaj
thanks! NICOHOLICZ
H8tred
What did you decide to go with? I'm a big fan of Syncromesh in Honda transmissions, but they use yellow metals. I don't know what's in Nissans.
Jookmasta
been using lucas oil for the past 7-8 years.............no grinds at all.............
H8tred
Jookmasta wrote:been using lucas oil for the past 7-8 years.............no grinds at all.............
After the side by side tests I have seen by people with nothing to gain from either being better than the other, I will never use Lucas products. Not even to start a fire...
H8tred
Not that I'm putting you down Jook. I've thought about Amsoil, as one of the tool trucks that comes by work carries it. Never tried any Red Line products though.
240sxvaj
alright so i just had to bring this thread back to life
how many bottle of redline mt90 will i need to fill up my transmission?
a guy from the shop told me 2 should be good but then wasnt too sure
TheOne
Car: 93 240sx FB
manual trans requires 2.6 quarts(1 quart per bottle)
either mt90 or mobil 1.(used both, both work fine)
240sxvaj
TheOne wrote:manual trans requires 2.6 quarts(1 quart per bottle)
thanks!
by the way nice sig
and which brand would you perfer more?
importdude
currently have mt-90 but im thinking of swtiching to royal purple syncomesh in (got 2 extra qts
240sxvaj
importdude wrote:currently have mt-90 but im thinking of swtiching to royal purple syncomesh in (got 2 extra qts
how are you likeing it so far?
2s4k0y09
Car: 1997 Nissan 240sx SE
+1 for Redline MT90. Have ran it for 2 years now no issues and percise shifts!
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
I have used Redline MT-90 and it took away some griding, and now that my motor got pulled and all that stuff,
I'll be going back with AMSOIL MTG 75w-90(NOT SEVERE GEAR). With all of amsoill's testing and "proof" of their product, it really makes them stand out. Not many other companies post up results with many other name brands..
remotecow
Car: 93 240sx
kool bro..
motoman399
Car: 98' wrecked (RHD coming soon) 240
redline MT90 fo-sho
chuy
MT-90 all the way,have fun changing it.
