jesse_tijero7 wrote:by the way, the tires i want are the Federal SS595...what you guys think, I've been looking at pics with the dimensions, and i like em'...would it look stupid to go 195/40/16? i don't like thick tires lol but i do want some with the right amount lol
you do know how to read tire sizes, right?
if not here is a guide
195/40/16 <-tire size right.
the first number is the width of the tire in this case it is 195 as you could imagine the bigger the number the wider the tire. Simple enough right?
Alright the second number 40 in our case is the sidewall height of the tire so respectively the higher the number the higher the sidewall. I think this is where your confused with the idea of a fat tire.
and the last number is rim size, again for us were using 16 which represents the 16in rim of your choosing.
now remember if your going to stagger the size of your tires from front to back, for example a 16x8 on the front and a 16x9 on the rear, your going to want to chose a smaller sidewall for the rear wheels so that the tire doesn't look twice as big. this is because as the tire gets wider the sidewall gets taller.
