, no i have RH5 rims i'm having clearence problems with them, so i'm selling them for new rims with a lower offset.McRussellPants wrote:Jesus your running over fenders on 9+35 and 7+38.
GRRROOOSSSS.
The problem with the spacer is that your trying to use a thin bolt-on spacer on ****ty knockoffwheels. Knockoffs usually dont have the pad designed for boltonspacers.
yea i wasn't planing on buying new rims, but i'm tring to match my widebody. Everything on my ride is authentic, i'm just tight on cash now for some big name rims.IWannaS15 wrote:Are you getting these from Ebay? The seller 'sgmotoring' always lists teh 17x7 offset as +38, but the sportmax site says its +40.http://www.sportmaxwheel.com/pr_wh_962.shtml
Of course, that guy also sells the wheels in bronze and in 19" size, and neither of those options are listed in the site.
I have 17x7 with about the same offset on the front of my car (s13 coupe) and with no spacer and stock fenders they are sunk in quite a bit. Not flush at all, I need some spacers but haven't gotten around to it yet. A 17x7 +38 with +15mm front fenders is going to need a huge spacer to look flush.XTCshri2222 wrote:17X7 Offset +38 23.5 lbs ea. 17X9 Offset +35 25.2 lbs ea.
specs of the rims
