best tension rods?
dades14
what are the best tension rods for an 96 s14?
Slappy
Car: 1993 240 sx coupe
I'm so sick of having to say this. There is no such thing as the "best".
Do some freakin research on your own. But if you need a answer right away , there are companies like Battle Version , SPL , Kazama ect.
dades14
if your so sick of it then why did you answer it? your not force to
giodachamp
Car: Nissan 240SX S13 (180SX)
dades14 wrote:if your so sick of it then why did you answer it? your not force to
i think what your trying to say is what brand would you reccomend for a tension rod
Slappy
Im helping the kid out by telling him to search and learn some things on his own , and did you fail to notice the references i gave him?
giodachamp
Slappy
Pr0jeCt
OEM with poly bushings worked good
Slappy
Pr0jeCt wrote:OEM with poly bushings worked good
Yup. But you cant adjust your caster with OEM.
dades14
why should someone adjust their tension rods for?
Slappy
Caster. Lengthens or shortens the wheels base.
Stability at high speeds or more grip while cornering.
http://www.vrperformance.com/m....html
http://www.google.com/
94_240sx
Car: 94_240SX
SPLKazamaBattle VersionIkeya FormulaCuscoProject NissanARC...
churro
Car: RHS13 ('89 Hatch)
I'd look for ones made out of steel. I've snapped a stock rod in half. I don't see how an aluminum rod could hold up very well.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
i was reccomended spl myself...thought id pass it on.
Slappy
churro wrote:I'd look for ones made out of steel. I've snapped a stock rod in half. I don't see how an aluminum rod could hold up very well.
And what did you do to cause that stock rod to snap?
naed240sx
Car: .....
I can safely answer the original poster's question by saying SPL. They are the strongest, best quality, best heims, and offer enough adjustability to go from stock castor to upwards of 10 degrees. No other company offers that.
KDashy
Car: '97 Nissan 240SX
Im not sure how you did that to a STOCK tension rod. I did this to mine after crashed.
LCA was F'ed, but the tension rod only bent slightly.
s13fOr_me
Car: 240sx
i love my kazamas.
Slappy
naed240sx wrote:I can safely answer the original poster's question by saying SPL. They are the strongest, best quality, best heims, and offer enough adjustability to go from stock castor to upwards of 10 degrees. No other company offers that.
Thats what i run , the SPL V2. But i have'nt compared them to any other brand so i cant really say much.
churro
I gave it a good whack with a curb, and mine broke around the inner stud. It's the weakest part, and it just might have been defective. My LCA looked like a boomerang though.
Now that I see both pictures though, I would say the S14 has slightly thicker rods.
Slappy
Well , there you go. You cant say somethings crap when you go smashing into curbs.
churro
I didn't say they were crap, I'm not even saying I'm surprised that it broke. All I'm saying is that it took quite a deal of energy to break that piece. Had it been made of aluminum, more of the impacts force would've been transferred to the frame.
Clawhammer
SPL +1
