best technique to remove driveshaft bolts
mattback
Car: being a big f'ng ricer
anybody ??
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Liquid Wrench is your friend. Make sure you use a socket with that matches EXACTLY to the bolt. Not just the size, but number of points as well if it's really tight/rusty. You can use a breaker bar if you have room, just be careful.
trpower7
yeah, you have to use one on either side, otherwise the whole thing will twist. When I did my differential I had to take out a ton of bolts like this, but once you get in the groove it isn't bad at all. PB Blaster will do great for breaking all that rust off.
themadscientist
Uh, Alex what is a wrench? I'll take putting on an oil filter for $200.00.
Thor
trpower7 wrote:yeah, you have to use one on either side, otherwise the whole thing will twist.
Might help if you put the car in gear and engage the emergency brake.
