Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Nov 28, 2003 2:45 pm
the springs themselves look great, the problem is KYB specifically says the AGX isnt made to handle spring rates over 50% higher than stock... or 3k springs(like the tein s-tech, or many other street springs)..now I would think you could run a slightly sitffer(say 3.5 to 4k) spring, and run the ax on its higher settings and be "ok", but that'd be pushing it.
apex, and a few other companies in japan make very stiff shocks, that would easily handle the spring rates of the RSR and Kg/MM, but...the only US availalbe ones I have seen are the KONI, and those arent adjustable withotu taking the shock off in the rear. you may want to look into GAB short strokes...I think those mjight hold up, or some bilstein HD's, but they'll cost quite a bit...probably more than coilovers.-chet
