best spark plugs
Bigrolla
what sparks plugs does everyone recommend for a ka24de. Brand and material type.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
NGK
Bigrolla
should i run ngk iridium on the irdium ix or just stick with the copper bs
180fan
Car: 89 fastback
IX are less maintainence over the long term and cost about 5 bucks each.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
Im running the ngk v-powers.. coppers perform better so i read.. i dont mind changing them out every 15-20k miles
max
s13sr20chris
ngk v-power plugs are the best but you have to change like every year or so. no big deal in a ka24. what does it take? like 15min?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
I had very good results with denso Iridium
8 bucks a plug thou…ouch
Drifterxl
Car: 1990 240sx FB
i'm gonna be throwing in bosch platinum 2's in mine later this week. they were on sale and i figure, hey, its bosch, so its gotta be good right? whats the word on these ones? how do they compare to the ngk's?
180fan
Car: 89 fastback
i've heard bosch don't work well in nissans. personally I stick with NGK. thought about going to denso but after another guy had his ceramic section blow up in his sr, I decided to stick with ngk.
s13sr20chris
bosch platinum=no good. the old bosch super plugs were fine(not the bomb, but fine). bosch platinums, +2's, +4's, etc are no good. the electrode is in the wrong place(hold one up next to an ngk plug), the ceramic is weak, and they just fall apart in no time. if you want to use them then do this.1)take a picture of plugs and then install them2)wait two weaks, pull plugs, take another pictureif at this point you still have some center electrode on your plugs then you can put 'em back3)wait two more weeks, pull plugs, and take another picturei assume you have been driving the car during the two weekscontinue...examine the pics. can you see how the electrode is wearing quickly?thats why i hate those spark plugs. i have no problem with the denso plugs. i figure nippon denso is a good manufacturer right? well so is bosch. ngk plugs are just perfect.
Bigrolla
bosch = poo in nissan belive me i know, i chunked mine after like no time at all
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i can get NGK plugs cheap.... Only laser platinum, PFR5G-11 and 6G-11
Bigrolla
I just got ngk irdium ix plugs and im very happy with them
thelinja
Checkered-Member wrote:I had very good results with denso Iridium
I'm interested to know what kind of "good results" you experienced. Dyno?....or?
[s3]
NGK Oem plugs, unless you're boosting..go with colder ranged plugs.
all others are waste of money
Absolutley NO HP gains from plugs
s13sr20chris
you can however loose horsepower with plugs. thats what the bosch plugs will teach you. put them on the dyno. mike kojima has.
edit: i believe mike k's writeup is on sentra.net
Checkered-Member
thelinja wrote:I'm interested to know what kind of "good results" you experienced. Dyno?....or?
i love this guy "dyno" yeah right....
idle is smother, higher RPMS are smother...mpg has increase by 2mpg...car starts a little faster then before
thelinja
cool, that's what I was interested in
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
today i went into action autoparts to get some ngk v-powers for my car and they told me they are not the right appliation for it.. that my car has to run platinum plugs or something, they even showed me that theres i no v-power plug for 240sx in their little book that shows about the spark plugs.
Max
silencer.1
Car: women, my car, paintball
They don't know what they are talking about, I just put 4 new ngk v-powers in my engine yesterday.
Bigrolla
i had v powers in mine too
thelinja
EstoMax wrote:today i went into action autoparts to get some ngk v-powers for my car and they told me they are not the right appliation for it.. that my car has to run platinum plugs or something, they even showed me that theres i no v-power plug for 240sx in their little book that shows about the spark plugs.
Max
It won't come up on their computer. When I buy plugs I just give them the code. The code for the V-power plugs is : BKR6E-11.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
6e?is 6 the normal heat range?because at the other shop they gave them to me, and i got bkr5e plugs.. which ones are correct? cause ill go get em replaced i havent put the new ones in yet. i have 5e's in right now..
max
thelinja
either one is fine
s13sr20chris
5 is the hot plug. its better for short trip driving and granny style driving. 6 is the normal plug. 7 is the cold plug which is better for long trips, hard driving, and hot climates.
