evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Mar 11, 2007 5:47 pm
Welcome to Nico!some trim levels of the Z came with 18' wheels stock, in gerenral the larger the wheel and shorter the sidewall on the tire the rougher the ride, but the rougher ride equalts less sidewall flex which is a good thing when talking about performance, there are limits to this, "dubs" are definitely over the top and add more weight than anything, also keep in mind most larger wheels weigh more and will serve to slow you down, which is where CCW and SSR and other brands come into play, you just have to decide if you want a cruiser or performance, if you are concerned about ride quality you should keep it on the small side, if oyu prefer the look of larger wheels you might be willing to sacrifice some comfort for the look or performance advantage of a larger wheel
