slip69 wrote:sorry if this has been asked before..i tried searching but no results. i wanted to go with 18's but was not sure if they would fit ok and if there where any problems reported with 18's cause of the excess weight on a vert. thanks
Are you buying tin rims? The weight of the convertible will effect the rims you choose. I've not heard of few extra pounds causing a rim to fail. Now if your putting some 18 x 7 cheap knockoffs on a H1 hummer... then you might have a problem.
As for looks... I've seen some nice 18's on a 'vert and I've seen some that just look a little big. I've got 17's on mine, and they actually look a little small for the wheel well.
Anything from 16's to 18's should be just fine depending on your taste.
