Best size exhaust for the Tiida MR18DE
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
moz@
Car: Tiida STL
Hi everyone,
I wanted to find out what is the best exhaust size piping for the nissan tiida 1.8L (MR18DE)?
The only other mods i will ever do is a pod filter, and i dont want to loose any power at low revs.
I am planning on getting a Cat-back system Mandrel Bent with a Maganflow Hi Flow Cat, and an offset straight through muffler.
So how many people reckon i should get 2" or 2.25"???
themadscientist
based upon the average pipe on a CA18 muffler I would say 2".
blindsnyper
Car: 2007 versa
i have 2.25", but honostly i have no clue what would be better. i have also heard of 2.5".
themadscientist
If the car loses torque down low it's likely too big. Leaving the cat in might make the bigger pipe after a better size than 2"Most of the SR20DE and CA18DE mufflers use 50mm pipe though.
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
blind_snyper wrote:i have 2.25", but honostly i have no clue what would be better. i have also heard of 2.5".
Anything over 2 in is too big for an NA 1.8l 4 cyl.
#1Tango
the stock exhaust is already 2" mandrel bent. just cut out the resonator and BAM!!! you got a cat-back. just change out the muffler and your set.
Return to “Versa Technical Discussions”
