Primer55 wrote:Bull****, I have seen the Horsepower specs (gotten from my friendly neighborhood nissan dealer) that show the Injen CAI w/ Filter gives a 25hp increase at 5500 rpm. Now it doesn't matter what your 240sx maxes at, they test the engine from 0rpm to 8500rpm/9000rpm, and its horsepower increase peak was at 5500 rpm (5hp was the average increase of the set interval: 0rpm-8500/9000rpm).
2) Maineimport: What do you think the resistor does, it slows the circut in the car's computer to allow mere fractions of a second longer (were talking 1/10000ths of a second, maybe less) to allow more fuel and horsepower into the piston chamber (at least that is what it should if you look at where you hook it up). I called it a "chip" simply because I have no better word for it, and that is what it looks like.
PS:I will try and attach the readout spec I got from the nissan dealer (I have a friend in the service dept who has a car like mine (1996 240sx SE) he has been doing things to, he's helped me out a little with this). He ran a total horsepower readout on his car w/ stock filter, w/ Short RAM, and w/ CAI yesterday to help me out (I wanted to know which is better) and If I can scan it in and attach it I will show you.
I'm not about to start a flame war here... but if you want to believe you got 25 HP out of an intake, you go right ahead, I won't stop you. By the way, if Injen could get a 25 hp gain from their CAI ... THEY WOULD ADVERTISE IT AS A 25 HP GAIN!!!!! Do you really think that they would only say, "upto 5hp gain" when they could get away with saying 25.... hmmmm I think not. I'm curious why your local Nissan dealer allowed your engine to be revved 2500rpm past redline, that was really nice for them to do that to YOUR car! As for the resistor, you are wrong again, it doesn't slow down the signal. Any knowledge of electronics would clear that right up for you. It sends a constant signal of 3.3k ohms of resistance to your ECU... as opposed to the variable resistance provided by the IAT. And for the record... as was discussed in a previous thread, the IAT is for diagnostic purposes only, and doesn't directly effect the ECU or engine systems.
I promise you, if your local dealer told you that you gained 25 hp... they are wrong, and they are misleading you. The ECU timing resistor is pretty much useless... I have it, I've used it with and without... and it makes NO noticable difference. I'm honestly not trying to ***** back and forth with you, but the HP thing is just way off. Did the dealer dyno the car before and after the install? Something is wrong with those figures.... totally wrong.
