best shocks for the datsun 720 best bang for buck
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Project Trucker
Car: Datsun 720 pickup
hay im gonna be replacing a few parts here soon including all of the shocks hopefully and the front ball joints i was just wanting to know what i should get brand wise and shock wise i want the best bang for my buck enexpensive but very good now remember out here im more partial to offroadin through the adobe dirt roads more like rally so just gimme some feedback
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I read that you should go rubber over poly for bushings.
breadbox
89 Koop
84 720 4x4KC
both of mine have monroe shocks, IDK. they're bright yellow.
PEZi
i got KYB monomax front and gas-a-just rears
Project Trucker
thanks for the suggestions
h2theizzo
Car: 1980 720, 1985 720 KC 4x4, 1980 4x4
i used some pinto shocks in the front then kybs in the back
poly bushings are good
guamsmith
Car: 1986 Nissan 720
I used Toxic shocks (Stylin Trucks $38 each) for my front which provided me with a smoother ride and made for lowered vehicles. Rear set is Air shocks (Craigslist $30) controlled by an Air Ride compressor (JC Whitney $95) which allows ride and height adjustment on the fly.
snakecbaker
Car: 1985 nissan 720 king cab 2wd
iam looking to lower my 1985 nissan 720 king cab st 4inches and not sure what shocks to run. Iam thinking of ford pinto in the front or mybe mustang 2 shocks. Does anyone have an any ideas witch ones would work the best. Iam hoping not to spend a lot that why i was wonting to use the pinto so i just can go to the local parts store.
Aven
Car: 84 720 Kingcab
From what I could find, the difference between rubber and poly is a trade off. Rubber will last longer, yes, but poly will give you a smoother ride. Considering I-5 is about 40 years past it's prime, I'm going with poly. I should have two boxes by tomorrow of various bushings.
dogred
Car: 1983 D720
I got the bargon basment shocks form Oreilly's and they were $16 each for the front and $25 each for the rear. Drastic improvement from the blown out ones I had.
86 720
Car: 1986 720 4cyl Standard Cab
dogred wrote:I got the bargon basment shocks form Oreilly's and they were $16 each for the front and $25 each for the rear. Drastic improvement from the blown out ones I had.
X2...
Firestone wanted to charge me $50 per shock plus labor for their "base" shock, total cost $300. Went and bought some from Autozone and installed all 4 in an hour.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Down here we have KYB, Koni and monroe. Haven't priced any as yet tho.
dogred
Car: 1983 D720
Monroe will be cheaper than the KYB's but the KYB's are better. Both brands have their entry level and high end versions.
flinterman2000
Was considering using a Koni from a Ford cortina for the front. They're almost identical.
Return to “Datsun 720”
