Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Tue May 13, 2008 9:28 pm
The Quality of the following parts can varry greatly and may depend on the type of motor you want (Turbo, NA etc.) Your Rebuild kit should contain the following:CrankPistonsConecting RodsRingsBearingsNew Oil PumpNew Water PumpA FULL gasket set including front and rear sealsTiming chain and gears including guides and tensonersValve seals
Optional depending on your budget and future desires:New cam (or Cams if you have a DE)New Valves
Good time to change the folowing:Plug WiresCap and RotorAll Hoses (radiator and heater)TermostatRadiatorRadiator CapFuel Filter
You will need the folowing on hand:New Spark PlugsOil FilterOilAnti-freeze
Like I said that is what you need. Buy the best you can afford. It will handle Turbo better and if you never go turbo it will still be a good strong motor that should last a long time.
