BHFR-GTR »
https://forums.nicoclub.com/bhfr-gtr-u98348.html
Fri May 08, 2009 11:30 am
i have run 4 sets of top hat mounts and have been fine, if you dont like the isolators then change them out still cheaper than everyone else, the psyko ones to me suck, as performance shop owner they dont work well for anyone who wants to lower there car, and most all 240 owners want to do that. they sit the motor to low causing the exhaust and downpipes to sit extremely low to the ground, they also position the oil pan to low to the ground as well the crossmember sits lower then the stock 240s. im sure the mckennys fit fine just are too high for what you get, the tophats position the motor is the best spot in the bay and shifters are perfect center. but all in all its up to you, just figured that you might want the opinion of someone who installs them for a living
