Greddy is overated, considering the cost of Koyo and the fact that they are a radiator specialist, i think id go with the one that has more/better experience in rads.....Koyo is cheaper also.vutony wrote:Checkout Greddy, 3 row core...you might want to add dual fans and fan controller, nismo thermo would be nice
-KOYO Radiator $289 shipped from Marty T from Injected Performancerhd_kyle wrote:Im about to get a blacktop sr20det, and i live in east texas. For those of you who do not know it get over 103 temp and its really humidity most of the time so i need a really good radiator.. Im going to be drifting the **** out of the sr20det. I do not wont to go cheap.. And i want the best radiator i can get.. I have try to seach and it is all koyo, and thats fine if that is the best.. Ok thats cool but i just want to make sure they are
im also going to put fans on the radiator is dual or single better? And what brand
to summarize:best raidiator $550 or under for east texas heat:fans dual or single and what brand:
theclub wrote:Aluminum is just for looks, the 3" wide koyo al. radiator is still not as good as the .75" koyo copper radiator. With your extra money buy samco hoses.
Heres what it really comes down to:Core design, and not material (copper vs. aluminum). and adequate air-flow are the most important aspects for obtaining maximum coolant temperature drop from radiator inlet to outlet.from random websites wrote:Competitive Advantages of Copper/Brass Radiators(Versus Aluminum Radiators)
Technical
* High thermal conductivity * High corrosion resistance * High tensile yield strength * Higher melting point * Lower coefficient of thermal expansion * Higher modulus of elasticity * No-flux brazing * Easy repairability
Commercial
* Lower fabrication cost for tube and header material * Well-established recycling tradition (infrastructure in place) * High scrap value * Well-established aftermarket tradition (infrastructure in place) * High-quality reputation
Because copper/brass cools more efficiently than aluminum, a copper/brass radiator can be smaller to reduce weight and space. One new design with a "compact core" dubbed "Cu/Br II" has two rows of fins between tubes and thinner tube walls. The radiator is about 7 percent lighter and 15 percent smaller than an aluminum radiator of comparable cooling capacity.
The new brazing technology for joining the tubes uses a copper/nickel/tin/phosphorus alloy which provides a stronger connection and is more environmentally acceptable than soldering (which uses tin/lead solder). Brazing also means "solder bloom" (a type of corrosion that can form inside soldered copper/brass radiators) won't occur.
The inside and outside of the new brazed copper/brass radiator is electroplated to give it "unprecedented" corrosion resistance - which is an essential requirement for all radiators today. The radiator can also be easily repaired and recycled, the same as other copper/brass radiators (nearly all of which end up being recycled). Furthermore, the amount of energy needed to produce one ton of copper from copper ore is only about 40 percent of that needed to produce aluminum from its ore, so the overall energy picture for copper/brass is more favorable than that of aluminum.
Do some reading before you make assumptions...http://www.koolance.com/techni....htmltheclub wrote:Aluminum is just for looks, the 3" wide koyo al. radiator is still not as good as the .75" koyo copper radiator. With your extra money buy samco hoses.
One of the things copper is better than aluminum (radiators) is that its a green radiator meaning it can be recycled better. Like I have in the quote from some websites.* Lower fabrication cost for tube and header material* Well-established recycling tradition (infrastructure in place)* High scrap value* Well-established aftermarket tradition (infrastructure in place)* High-quality reputation http://www.copper.org/applicat....htmlRosco wrote:Do some reading before you make assumptions...http://www.koolance.com/techni....html
Alu absorbs heat better.Cu disapates heat better
Exactly. Thats why it comes to this like I mentioned earlier: Heres what it really comes down to:Core design, and not material (copper vs. aluminum). and adequate air-flow are the most important aspects for obtaining maximum coolant temperature drop from radiator inlet to outlet.Rosco wrote:I've read both sides of the argument on different sites now and both seem to be just as good as each other
