BEST POWERADDER?
silveradobeast
Car: 94 HARDBODY 2.4 5 SPEED
94 d21 5 SPEED 4X4 EXT CAB
PARTINNG OUT A D21
im looking for some performance parts for my 94 d21 2.4 5 speed, due to the fact that i always have it loaded with matterials and from time to time pull a trailer. im mostly looking for bolt ons but any ideas will help.
thanks,
pejsa s-13
Car: 91 HardBody, 85 720
call jason at emance tuning he is awesome at what he does. he charged me 75 bucks to tune my ecu and wow talk about bang for buck, i can rev up to 7.5 K and pull like a beast in 5th uphill now feels like a different motor.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
How'd he tune the d21 ecm? Did you swap it with a Stanza or something?
PEZi
Do you consider a turbo a power adder? lol
pejsa s-13
yea we swapped it for the stanza so i could have consult, but he could map the stock one too swapping it for a stanza one is choice
Rev_D21
Did he happen to keep the files? I have a Stanza ecm waiting on my bookshelf, socketed and chipped.
pejsa s-13
most likely nissans is all he does, youd have to look him up
benre
Car: 1997 Hardbody 2.4l 4WD
So, a stanza ecm does what for making a hardbody perform better? and will it work on my 97 nissan 2.4l 4wd?
pejsa s-13
it wont do anything, that i know of, i just did it so i would have colsult. get a stanza ecu and have emance tune it, good stuff
PEZi
benre wrote:So, a stanza ecm does what for making a hardbody perform better? and will it work on my 97 nissan 2.4l 4wd?
it does nothing.... but its tunable where the D21 isn't
and yes... it will work....
benre
So if i bought a stanza ecm, it would work on my truck, but I would have to get it tuned to give my truck more power?
Who would i get it tuned by?
Also, does this "mod" still allow the obd to work properly?
And, does this work with a 97 HB 2.4l 4WD?
Thanks for the info.
pejsa s-13
holy s*** dude ^^^^ beating a dead horse!
stanza ecu, emance tune, = more power, obd should be fine
the guy right above you said it would work
Rev_D21
There's a lot to this topic. eccs.hybridka.com has all the info. I gathered all the parts but haven't installed them as I haven't grown the balls to do it yet. I has to be a Stanza ECM from 91-92. Manual preferred but not required. You will also need to snip off the consult port and get some extra ecm terminal pins to add to the main harness. This is where I am at. What I did differently was I went with a jmhalder NVSRAM setup so my laptop becomes the EPROM, I will be able to modify settings while driving or dynoing the truck. The info out there is complex and scattered so good luck if you go this route.
benre
Sounds too complicated for me. I want more power, and if it was semi-stock I'd be all for it. Just too many unknowns. If the company sold ready to install units with directions I'd jump on it.
silveradobeast
PARTINNG OUT A D21
benre, i would too!! but is this all the performance we can get?
pejsa s-13
of course not, 240sx intake manifold, 240sx cam, high flow cat, cough cough turbo, ps, or ac delete, electric fans with a clutch fan delete, theres plenty of things
silveradobeast
PARTINNG OUT A D21
yeah a turbo sounds great!! but will the 240sx manifold bolt right up?
pejsa s-13
yes google it theres a pew write ups out there for it, the wiring is the only tricky part about it
silveradobeast
PARTINNG OUT A D21
pejsa s-13 wrote:yes google it theres a pew write ups out there for it, the wiring is the only tricky part about it
did you do it to your hardbody?
where is the best website to buy aftermarket parts?
thanks,
Rev_D21
pejsa, where did you get your chip and socket? What kind of chip did you go with?
pejsa s-13
no i just picked up my cam and manifold today =P
theres a good write up on it on infamousnissan (sorry mods)
and im not sure about places to buy aftermarket stuff
and i went with a stanza ecu and had emance do all the work cause the owner jason is one of my buddy's
Zion8561
Car: 92 Nissan S13 Fastback
They also sell intake kits on 4x4parts,com (just the intake, not a complete manifold). I don't know what kind of gain you might see, I plan on getting one soon though.
The other thing you could do is get a different ring and pinion for your diff.
pejsa s-13
the CIA for the trucks i belive is actually less power than running an open air filter on top of the TB, im running a k&n and noticed a little gain from it
seang
Car: Ford Fiesta ST
The KA24E is going to be a KA24E unless you get intensive with everything; and it is only 2.4 liters, so it will need a turbo to have any significant torque gains. You could build an essentially lag-free boost setup if you wanted to, for truck duties, and that seems like it would work pretty good.
As for that open filter, I ran that for about a year. It flowed good and didn't pull as hot of air as you might think as long as you were travelling along with fresh air passing into the engine compartment; but it was louder than stock. I could hear my injectors firing, and coupled with my new cheapo glasspack the cruising speed drone was intensified to where it was downright unpleasant on 50 mile highway trips. I reconnected all my stock intake tubing/intake resonator so the frequencies from the glasspack don't amplify themselves with the intake frequencies--at least not as much.
Zion8561
I just went and ordered the intake from 4x4 parts. I will let you all know how it works in a few weeks.
One benefit of that intake is that it comes with a metal box that bolts down to the throttle body. It looks like that can be used to connect the charge pipe for forced induction in the future, but i am not sure how strong it is until I actually get it.
