rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Fri Nov 28, 2003 6:38 am
Here are some things to look for when buying the car:
A good spot to check for rust would be to check the rear in the spare tire well under the tire. I've run into a few S13's where the taillights leaked and it's rusted back there. Look at the tie rod ends and the bushings in the tension rods as these are often overlooked when servicing.
Pop the lights up and check the pivot arm that connects the light to the pivot motor. If this arm jiggles it means you are going to have an annoying bounce to your headlight(s) when driving at night.
As for performance, fix the broken/failing items on the car first. Then start upgrading (of course upgrade the parts as you replace them).
Motor preference depends on where you want to go. As it's been said you can most likely get your goals with a KA in NA form with an LSD and some more aggressive gears out back.
I have done 2 RB swaps, and it's hard to think of going with anything less than these motors.
Whatever you do, do it right and you'll only have to do it once. Spend the extra money on a good body, you will be happy you did. You might be able to do a good roundeye S14 (95 & 96) for same or less than a good S13 due to the popularity of the S13 and sharkeye S14. Everything comes down to personal preference.
Hope this helps. Good luck.
