onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Sun Jul 24, 2005 9:55 pm
Well, I just ran my 0 gauge today through my 89 240sx, but should be relatively similar.
You should run it through the driver's side w/ the other power wires. Avoid the passenger since your ECU is probably over there.
Some ppl like to run it under their car, but 8 gauge is so small I don't see the need for it.
You can also probably reuse a hole already drilled (and probably covered up by a rubber boot) in your engine bay on the firewall.
When I did it, it was a lot easier after stripping out the driver side lower plastic trim & removing the driver's seat - much more room to work w/.
