I H8 UR DSM wrote:well you'd want to know the highest temperature vs the lowest....sure you can mount it even in the downpipe, but then its not actually the temp coming out of the head,ya know...some people do that, but remember then your 'warning' temps will be lower, since the 'actual' temp you want to be monitoring is cooled down by that point.
Just to further expand on what I H8 is saying; you monitor your EGT to keep from melting your pistons. Therefore, you want to take the temperature reading as close to the pistons as possible. Also, it makes sense to take the reading from the point that will get the hottest.
