Best place for an SR20DET swap?
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I know of Heavy Throttle and Unstable-Hybrids, but I would like some opinions from those with experience and also of any other reliable shops that will perform the SR20 swap. Any input is welcome.
Daunttless
I will be opening a shop that will be performing swaps in the next month, I'll also be providing engines. My SR20DET S13 redtops will be 2200, and my labor install on them will be 1000. I am reputable, you can ask around. : ) Unfortunately I"m located in Iowa, I'm probably about as close as Unstable is to you. Both Unstable and Heavy Throttle are great shops. : )
cnichols
99 Infiniti Q45
93 Ford Fastiva
Would there be any advantage to putting an S14 SR20 instead of an S13 SR20 if I have an upgraded turbo already on my KA that I will use on the SR?
Daunttless
I'm not 100% sure what you're saying, heres my guess.
You have a KA-T and you want to use the Turbo on a SR20.
If the above is true, it will not work, they use different manifolds, and chances are you have a T3/T4 or T4 on your KA, and the SR20 manifold uses a T25 flange.
The advantages to using the S14 are the better turbo and cams, equating to an extra 22 or so stock horsepower. That, and its a newer engine, its also easier to put into a S14 chasis wiring wise. Other than that, they're pretty much the same.
cnichols
99 Infiniti Q45
93 Ford Fastiva
The advantages to using the S14 are the better turbo and cams, equating to an extra 22 or so stock horsepower. That, and its a newer engine, its also easier to put into a S14 chasis wiring wise. Other than that, they're pretty much the same. [/QUOTE]
That's what I was saying, yes. I want to use my HKS GT series turbo on the SR. I know that it is not a direct bolt-on, but wanted to know what other advantages there were besides the ball-bearing turbo. That small increase in horespower is negligible considering I already have a FMIC and bigger turbo and injectors, but the wiring is something I didn't know of.
Do you think that the difference in cost would be worth it just for better cams and ease of install? But, since I won't be installing it myself, should I even worry about that? If there will be any reliablility issues from installing the S13 SR in to an S14, I would rather use the S14 motor.
Daunttless
There are no reliability issues, and if you are having someone else install it the wiring is not a concern either. : )
I would say buy the S13 SR since you already have the other stuff. Also, which GT series turbo do you have? any of the 25 series bolt on, if you have a 3037 you need a new manifold though. Although the turbos are worth it. : )
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Dauntless where are you located?
-Andre
Daunttless
Eastern Iowa.
Assuming you are in Alberta, I"m about 20 hours away from you.
ST240
Ok you said 2200 for the engine and 1000 for labour
but waht does "engine" mean
i still gotta get ahold of a BOV downpipe fuel pump and FMIC right?
-Andre
Daunttless
The engine is 100% complete, including the transmission, ecu, uncut wiring harness, and the stock IC and plumbing, everything.
You don't need a BOV, you can get one if you like. I would suggest the fuel pump, they're only 129 dollars. You will need a downpipe, I will be offering one for about 100 dollars, or you can get a greddy or blitz ranging from like 120-200 dollars. You don't need a FMIC, as it comes with the stock unit, but I would suggest an FMIC if you want to do anything above stock boost. : )
cnichols
99 Infiniti Q45
93 Ford Fastiva
I'm wanting to get my swap underway as soon as possible, and you obviously have the best prices, but I would like to know how many swaps you've participated in before committing. Also, I am wondering if your labor costs would include swapping my injectors, FMIC, and turbo, and any aftermarket parts I would purchase through you.
As of now, Unstable Hybrids is my first choice due to their proximity and prices, but I need to have confidence that your work would be equal to theirs.
Going back to our earlier posts, I do have the GT 3037 and would like to know how much the new manifold would cost and what options are available.
Daunttless
Hehe, we went over a lot in our IMs, I just wanted to see if you had anything else, and to let everyone know we've discussed everything. : ) Any other questions cnichols? : ) Were you satisfied with our conversation?
cnichols
99 Infiniti Q45
93 Ford Fastiva
We did have a lengthy conversation, but I think I got about everything I wanted to know. I feel a lot better now. I'm still tempted to go with an S14 motor, but I'll let you know as soon as possible.
dcmetro240
How much would an s-14 full setup cost? There is a local shop around me that has an s-14 engine and transmission for 2000. Not sure if that inculdes everything though.
Daunttless
My S14 SR20s are 3200, 100% complete with everything, including stock mount intercooler.
KSee777
Has anyone done this swap in TX? Preferably near Houston?
Daunttless
I'm only 10 hours north. : )
Justice
Car: turbo's
i havent bought a 240 yet... but i think im going to buy a redtop sr20 before i buy the car, keep my prelude as the dayly driver
ST240
sr20s can be daily drivers cant they!??! RIGHT GUYS?!?!?
heh
-Andre
Justice
Car: turbo's
i could daily drive it. but i whouldent want to with the car running 15-18 psi. as i understand it to get 18 psi, it whould just be fuel pump, injectors, turbo. basicly i whouldent need to rebuild the bottom end on her? "SR20DET"
Daunttless
Um, you'll need a lot more than that to get to 18 psi. You shouldn't need a rebuild, but you'll need basically every bolt on under the sun.
ST240
how much hp would you be running at that point
Daunttless
It depends on what turbo you use. : )
ST240
s15 turbo
Daunttless
almost 300 to the ground most likely.
Justice
Car: turbo's
well the car im shooting for is a 1990 240 xe
when i get it its going to be striped except for front 2 seats.
btw how much is it for the s13 front end conversion? that whould be a must=)
usuck
Sabs
Daunttless: Nice to see another Iowan on the board (a mod, no less). I'm from Decorah, where are you located? I'm currently looking for an S14 as my project car... I have a dealer checking auctions for me, and I'm checking whatever classifieds I can find. Should you see a S14 around $5-6k, probably a '95-96 SE, within a day's drive let me know. :) You may have a customer in the future as I'm considering an SR swap once I actually find a car, and take care of wheels, tires, and short shifter which will I feel will be mandatory.
Daunttless
i live in Cedar Rapids, and I know of a 95 SE for sale here, but its an auto. : (
Sabs
Just over two hours away, then.
No automatic for me. :p The hunt continues..
Do you have have a list of mods/pics for the car you're driving?
