andrave »
https://forums.nicoclub.com/andrave-u6358.html
Wed Jan 28, 2004 11:10 am
look at our cars, the ka24de was last available in the 240 in 98... so anyone selling pistons is figuring if you are building your motor up its probably a 100k+ motor (as most seem to be). And if thats the case, a bore and hone would do your motor good. cylinder get ovaled out over time...and boring is cheap, that is true, but its also true that machine shops find their way to make it expensive. Drop the engine off with forged pistons, they will prolly hot tank it, magna flux it, align it, bore it, hone it, button it up, replace the crank bearings, they make have to cut the crank, balance the assembly. Its hard to get it done on a tight budget.
