ok you gotta explain that onensrZ32 wrote:Automatic transmission fluid is what you want to use for your power steering
negatory, the parts store power steering fluid is much thinner and more prone to leaking, thats why nissan uses atf, thats what the system is designed for, you run regular power steering fluid and your leaks will get worse! the parts store also sells atf which is whats requiredfreakonaleash1187 wrote:The factory service manual recommends "Type Dexron", but just "power steering fluid" from the auto parts store should be fine, its all hydraulic fluid.
