Best offset for good flushness on S13...
andrewdees
Car: 97 Emerald Green SE
Soon buying the 5Zigen Fn01RC for my S13 w/ coilovers. With a 17x8 up front and a 17x9 on the rear. Whats the lowest offset I could run without rolling the fenders. I believe the 17x8 come in +25 and the 17x9 come in +15.
Question 2 - How do these rims clear the Z32 brakes?
thanks
-Drew
gumby74
The tire size will affect flushness somewhat. I am running the same sizes, just different offsets. +22 up front and +27 out back. The front tire is 225/45 and the rears are 245/40. My wheels are to the sticking out side of flush, if that makes any sense.When looking at the car straight on, the wheels are just past the fender line. I have no rubbing up front, and the rears required me to bend in the lip a little. Let me figure out how to post pics so you can get a better idea.
nismofly
Car: 89 Nissan 240SX Hatch
get the 17x9s all around
i take it youre 5 lug from the offsets you listed, so get the +15 all around, and run a 235/40/17 tire
-2 camber front, -1.6 rear, give or take a few tenths depending on your fender work
gumby74
So thaaaaaats how you do it.Anyway, this is a sideshot and a down shot of the rear. Sorry these are old pics.
SmithSR
Car: 240sx
Way to go, Mexico!
yokota180sx
Car: 1997 Stagea RS4, r34 front
18x9 +0 front18x10 +10-20 rear
andrewdees
So the 17x9 +15 up front will give me no rubbing or will I need to finesse the fender a little? Im sure they will fit in the back with no rubbing. I would like to run the same size tire/wheel at all 4 corners so I can still rotate. Would the +15 offset on the front make them "frog" out to the sides of the fender or will they sit nice and flush? I dont mind a little rolling of the fender if I have to.
Also would there be any clearance issues when I upgrade the F&R brakes?
Thanks!
-Drew
adrianfromthecastle
Car: 1992 Nissan 240sx
you should be good to go with z brakes...
but roll your fenders anyways... use a baseball bat and hammer if you need to... er else you'll chop up your tires with every hard turn you do
andrewdees
Okay sweet, and those wheels will clear coilovers with those offsets and widths right? I just wanna make sure before I buy that they will fit. thanks
-Drew
