There was a Cadillac a while back. It was called a V8/6/4. It was a disaster. The purpose was to improve fuel economy. I understand that the new system is better, but I'll reserve judgment for a few years. The purpose is again to improve fuel economy. Nissan is probably waiting and watching, IMO.TJMaxx98 wrote:Does anyone know why only GM has tried limiting the number of cylinders working at a given time on their v6 and v8 engines? It's like power on demand, but otherwise you would be getting the benefits of a 4 banger? If Chevy can do it why not Nissan/Infiniti?
Why not, we have CVT why not CVE (constant variable engine)?
I believe we will be seeing more Diesel engines here in the US in the not too distant future. They are already widely used in Europe where gasoline is over $6 per gallon.My 1980 VW Rabbit Diesel was up to 246k miles when its oil pump failed & I decided to get rid of it. At a steady 55MPH it got 55 MPG. The problem was that during the 1979 oil crises diesels were in short supply & I could only get it with a 4 speed manual. Had 5 or even 6 speed manual transmissions been available the MPG would have been even better.We need more and better public transportation in this country. How many of us sit in bumper to bumper traffic with only one person in each vehicle.Sentientbydesign wrote:We all love our Gs.
We all love the power.
We all prefer to pay less on gas, get more miles per gallon, and/or have cleaner air.
Here's the plan :
Devise a system by which significant fuel economy can be gained without sacraficing the potential for power.
The questions:
What options are available or can be devised to increase the fuel efficiency on the G (when you want to drive conservatively), yet still allow you to open the car up when you want to?
Are turbos only efficiency boosters on small displacement diesel engines?
Can a stand alone fuel management system be setup to run very lean and very rich with the switch of a button?
My goal isn't to create a savings where one doesn't currently exist. My goal is to reduce my environmental foot print on the earth, while forging ahead and also increasing my fuel tank range (in miles).
You're missing the point. The idea is to improve upon the platform we all own, not to give Nissan idea for future cars.TJMaxx98 wrote:Ok what about hybrids? I like how Lexus combines the gas and electric motors together on the RX 400h. 0-60 time in 7.3 and MPG of 27 city and 24 highway for the front-drive models. I could live with that level of performance.
How about putting a simular setup on a G35 vs a SUV with a Curb Weight of 4190 lbs?
If we could keep current performance numbers and average 30 mpg or better, I would not mind the combo gas/electric.
Sorry, I got off on a tangent there... You're just asking what mods we can buy to make the G more fuel efficient.Sentientbydesign wrote:
+1C-Kwik wrote:The problem is, the weight of the 'dead' cylinders are still being carried by the working cylinders. From my understanding a limited amount of compression still occurs, but that is probably offset by the spring effect the compressed air will have as it decompresses. But there is still friction and weight to deal with. Frankly, I can't make much of a strong case for it.
The two technologies I'm most interested in is direct injection and infinitely variable valve actuation. The G37 is using a version of the latter, but it's hard to quantify it as it is using it on a bigger motor. And from photos, it appears it may make for a heavy valvetrain. But in theory, the valves control the intake of air so you reduce the need to choke an engine with a throttle to reduce airflow. It can also maximize volumetric efficiency at all times if applied correctly.
Direct injection has shown to have great results on power and economy, but last I heard, it's biggest promise to ecnomy, which is the lean burn capability, introduces a high level of NOx emissions due to the higher combustion temperatures associated with leaner burning.
Both can offer some measurable benefits without sacrificing power (To some extent, it may increase it).
Frankly, it's a bit hard to really discuss it as there is no hard data on what the product does. At least the specific processes. I can't imagine water being broken down into Hydrogen and Oxygen atoms not taking a toll on the electrical system for the amounts that would be needed to have any real effects on gas mileage. Think about this. Several car manufacturers have been trying to come up with realistic hydrogen powered cars, investing a lot of money, including subsidies from the government. It's highly unlikely that an effective solution is this simple.justjuiceit4 wrote:I briefly watched the video for this product: http://www.preignitioncc.com/HCM/index.htmThe current HAFC unit seems very gimicky, but could have some merit for improving gas mileage, but not exactly the way that they describe. I remember Smokey Yunick mentioning something about pre-heating fuel for some fuel economy gains. It appears that they are using some kind of additive to the gas tank which claims to clean out the carbon in your engine. This also acts as an octane booster. My guess is that the main computer of this system bumps the timing to make the engine more efficient and/or leans out the fuel (hence why a qualified technician has to tune the system!).
I am too lazy to do the calcutions for how much hydrogen gas would be required to actually offset the use of gas, but I doubt it it does much.
Just some food for thought, I am interested to see what C-Kwik has to say about this!
Absolutely. As for the knocking conditions you speak of, it would perhaps point in the direction that the fuel may be combusted as it is being injected (similar to a diesel). This is something I was thinking would have been a huge plus, but I didn't throw in any thoughts of higher compression into the equation. The higher CR would be a huge plus. Being that car manufacturers have been bumping up compression incrementally, with existing fuel delivery systems, it would seem to me that DI could offer a huge step in this regard. Hopefully they can get a handle on the emissiions issue though so we might see this technology become more widespread.adren77 wrote:The reason for higher NOx emissions in DI engines is not necessarily due to lean combustion. High NOx comes from the fact that stratified fuel injection will cause localized combustion (rather than premixed homogeneous) which causes higher peak temperature. Also DI engines gain on efficiency due to higher compression ratios since knocking happens under different conditions. Higher cr = higher thermal efficiency.
I have several engineer friends at the "Big Three" and they fool around on the internet a lot!C-Kwik wrote: But as a general rule, just think about this. If the manufacturers of automobiles, who likely have huge staffs of engineers and scientists (likely very good ones at that) aren't implementing even some of the simpler devices, do you really think they work?
If you really want better gas mileage, get a more economical vehicle.
Sorry, I got lost in the other posts, and never answered your question. Yes, just as with the timing, with the EManage Ultimate you can set up different fuel air maps, and switch them as you wish, provided you have a laptop hooked up.Sentientbydesign wrote:
Anybody hear about HCCI (or PCCI), Homogeneous Charge Compression Ignition? A lot of research is being done on this. The point is to get a benefit from both Gasoline and Diesel engines. Gasoline engines have nearly constant volume combustion, while diesel engines have a lot higher compression ratio which. Both of these aspects contribute to higher thermal efficiency in the engine, which are combined in HCCI.C-Kwik wrote:
Hey rn... what site? There's no link.rn79870 wrote:Here is another cite for one of those 300MPG carbs. (Don't hold your breath)Scroll down to the answer by Cecil Adams for some good information written by a SDSAB member. (Cecil Adams is a fictitious, the SDMB is not)Where several ideas and possible future technology is revealed.
In other news, they are forecasting $4.00/gallon gas here in SoCal by spring. If you're looking for a good SUV I'll bet there will be a backlog on the dealer lots by then. Backlogs on dealer lots is not good news for the economy, neither is $4.00 a gallon gas.
