Best n/a exhaust
Dcasil80slider
Car: 1993 240sx se sr20det fastback 5speed
Ok im looking to buy the best exhaust for my s13 hatch. it will have a 95 ka24de in it however. It will have a injen cold air intake and the 248 248 cam swap from my earlier engine and possibly headers with either a test pipe or just a high flow cat. i wanted to put in a Apexi gtr spec exhaust but its a turbo exhaust and i was wondering what kind of effect it would have on the torque numbers without the normal backpressure that was provided by the stock exhaust. Also looking into headers for the 95 engine will s13 headers work with it ??? and also will a 93 injen cold air system work with the newer 95 engine ??? any input on these multiple subjects is greatly appreciated !!!!!
KA RPS13
Car: 1993 Nissan 240SX SE Fastback
Yes your intake will work as long as both were the KA24DE. As far as exhaust goes the 3 inch loosing backpressure myth is a lie. There are dyno sheets on fresh alloy that prove it having gains all around and no cons what so ever. Mind you on a n/a it will be loud, nothing a silencer and a resonator can't fix or just not driving like a jackass.
I got my exhaust from ebay, nissangtrpower was the seller. It has been great for me so far. I like the sound, I am not sure if they have them for the s14 though.
Dopefish
Car: 1995 Nissan 240sx
I'd try the 3" SSAutoChrome Dual-N1 style exhaust with Resonator. They sound pretty good. (Loosely similar to BRM in sound) It is very affordable as well. The resonator will tone down the drone while still offering great performance.
As for backpressure, its a myth... the feeling ofloosing power down low after installing a large diameter exhaust is merely the powerband smoothing out. The power is gained still but te deliery isnt as rough since there are fewer hurdles the gases have to push throgh. Without the surging that comes with a peaky band the power may feel weakened while in reality that it is improved.
~Kris
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
apexi gt is 3 3/4. I would go 3 or less for na. I have rsr gt2 on my na s13. searc this topic is coverd once a week it seems like
InsanityInc
Backpressure does not make torque. Ignore anyone who tells you that, because they know d!ck about engines.
3" seems to be ideal from what I've seen.
Dcasil80slider
Id really like to go with the apexi gt spec should i have any other problems other than a higher noise level ? Also i will be using a high flow cat instead of a test pipe unless somebody can point out an advantage of the test pipe to me. Also still trying to find out if i can use s13 headers on a 95 ka24de in my 93 hatch, iv heard the flanges are different but is this true ???
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Dcasil80slider wrote:Also i will be using a high flow cat instead of a test pipe unless somebody can point out an advantage of the test pipe to me. ??
Unless you want/need to pass smog a test pipe is significantly cheaper than a high flow cat!!
Lets see here....testpipe under $40, highflow cat...at least $150 usually more.
se-rious
Car: 240SX SE S14, FC Turbo, b-13 SE-R, AE86 GT-S
just be careful when you go with 3" piping. my friend had 3" piping on his 240 and he kept revving up his car to show me how loud it was with the silencer. next thing you know the silencer popped off and broke his neighbor's car's windshield.
InsanityInc
se-rious wrote:just be careful when you go with 3" piping. my friend had 3" piping on his 240 and he kept revving up his car to show me how loud it was with the silencer. next thing you know the silencer popped off and broke his neighbor's car's windshield.
Or just get a system with a real muffler and a resonator so you don't need a silencer.
Dcasil80slider
I was looking at the apexi and also a megan racing turbo exhaust there both "real" exhausts and yes i do have to pass m.a.r.t.a. here in tn, the apexi for expensive as it is is it really worth the money or should i go with the megan ???
BlackFlag_s13
Cyrus240sx had a GT Spec on a N/A Ka s14. He's sold his car since but maybe you can dig up an e-mail adress and ask him some ?'s.
InsanityInc
just buy a BRM exhaust.
http://www.brmusa.com
Dcasil80slider
Looked into that and also found a fujitsuboro on ka-t.org anybody have sound clips of this on a ka ? also looking fo sound clips from a ka with the apexi, megan, and brm if anybody has em my email is [email protected]
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
how bout the Apex N1, i have that running right now in the Ka24DE, is that true that im loosing power?
Dcasil80slider
I havnt heard much on the n1 recently dont think alot of guys are running them. If i was you id check out the brm i just did and WOW!!!!!!!!!!! save the cash for it made in america, made by nico, made 4 u what more can you ask for ??? drop Azhitman (greg) a line for one of these exhausts i think youll b satisfied .
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
Dcasil80slider wrote:I was looking at the apexi and also a megan racing turbo exhaust there both "real" exhausts and yes i do have to pass m.a.r.t.a. here in tn, the apexi for expensive as it is is it really worth the money or should i go with the megan ???
i just purchased the megan for my 93 se and i got a very good deal, they are having a sale until the tenth of march, you can find it on the marketing posts or just call megan up.
i can't see any exhaust being any different that the other, maybe just the muffler making it sound a little different than the next, the one i purchased is the drift spec, it's 2-1/2 with resonator and silencer. and for mandrel bent stainless steel exhaust it was a GREAT price, considering i have seen exhaust with the same specs going for up to $600!!!, what just for pipe!!! and a muff.
steaminhotryce
Car: 2002 Subaru WRX Sedan
If you want a quiet 3" exhaust, go with either the RS*R ExMag or Blitz Realize TT. I'm running the Blitz Realize TT with an AEM SRI. The Blitz doesn't require the butt plug silencer and yet it is extremely quiet for a 3". It produces a bit of noise in low RPMs, but not too loud. Deep sound. At high rpm or cruising speeds, you'll barely notice any sound at all. Pictures of the exhaust are on my cardomain.
S3t0_S13
so if u have a 3 inch pipe on a non-turbo are you losing power and torque? cuz i have the N1 on rit now
2kul
Car: 1990 S13
I just got my MeganRacing turbo exhaust 3" all the way for my na ka24e on monday...sounds so good! . The car picks up so much quicker too. But it is loud to. I'll be putting a resonator on it. Worth the $250.
Rod
Car: 92' Nissan 240sx
Kind of late for the feedback, sorry... but I have an Apex GT exaust on my hatch and I love it. I have the hotshot headers with resonator and catback with Jim Wolf ecu. Smooth powerline delivery and the engine revs lovely. Good luck with the Megan one.
