best muffler for 94Q?
Magnum PI
Car: (former owner of1994 Q45t)2005 Dodge Magnum R/T, 2008 350Z
I'm looking to replace the rear muffler on my 94 Q45t. Any suggestions of brands and models? I read the threads that say that there is no horsepower gains to be made there, but my trusty rusty muffler needs to go!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
i use walker dynomax others here like flowmastersi get mine from summitt racing, or jc whitney
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Magnum PI wrote:I'm looking to replace the rear muffler on my 94 Q45t. Any suggestions of brands and models? I read the threads that say that there is no horsepower gains to be made there, but my trusty rusty muffler needs to go!
I disagree that there arent going to be ANY gains, it may just not be much.. IMO, its a win win situation if you get a better sound and an extra few HP...
Many people here like dynomax..... get the dual in dual out setup..
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Stainless steel muffler shouldn't be rusting. OEM is by far the best unless you like vibration and noise.
Cannot add 15 hp even without one, so gains are unnoticeable.
Read Q45tech's posts for a comprehensive investigation of aftermarket setups.
Magnum PI
Thanks all. The muffler is OK, but the tips are rusty and look pathetic. Perhaps I should just replace the tips. I am not looking for HP, but it couldn't hurt!
elwesso
2007 BMW M Coupe
If your looking for a different but clean set of tips, look at summit racing... Borla makes some realy nice looking stainless steel ones... spendy, though.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
maxnix wrote:Stainless steel muffler shouldn't be rusting. OEM is by far the best unless you like vibration and noise.
Just dropping the 85 pounds of the factory muffler is like adding 15 HP to the engine.
tkd_q45
How about this?
http://page3.auctions.yahoo.co...46690
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Very nice, except it probably only has a single inlet.
tkd_q45
It came up under a G50/Q45 search. Should work no?
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
If you look at the Q, it is a true dual exhaust. The rear resonator has dual inlets and dual outlets. If that muffler doesn't have dual inlets, then you will have to fab something. That is why most epople say to get a dual-in / dual-out then add the chrome or stainless tips.
elwesso
2007 BMW M Coupe
Jeff Williams wrote:If you look at the Q, it is a true dual exhaust. The rear resonator has dual inlets and dual outlets. If that muffler doesn't have dual inlets, then you will have to fab something. That is why most epople say to get a dual-in / dual-out then add the chrome or stainless tips.
that must be a 90-93 exhaust because the 94s look slightly different..
Magnum PI
whatever it is it sure is ugly! I just put zoomers on my 05 Magnum RT (hemi), and those really flow. It is too noisy for a Q. A Q needs to be a bit dignified when it drops someone.
96qtrip
Car: 1996 Q45
got a a part number for that? to replace the q bathtub....
thx
96qtrip
Car: 1996 Q45
Wes,
I see in the picture of the Q exhaust system, there are two brackets,on the fronts of the cats. They both have bolt studs. Is there anotherbracket that connects the two sides? I had the drive shaft replacedunder warranty at 55K and wonder if the part got left out???
thx
elwesso
2007 BMW M Coupe
That part actually connects to the transmission mount. probably so that the exhaust doesnt shake....
96qtrip
Car: 1996 Q45
Thx - I crawled under and see the damper weighton the transmission, but nothing to connect a bracket to.Any real pictures of how it is supposed to be?
thx
elwesso
2007 BMW M Coupe
Heres a picture of how it should be, i highlighted the brackets in yellow.
96qtrip
Car: 1996 Q45
damn - perfect picture! Thanks very much, now to find them. I forgot tonote in the ohter post that the bolt studs did have wear on them; hence myview the parts were "missing"
Thanks!
