Best motor oil/filter for a 97 qx4?
cbaccam23
Car: 97 Infiniti QX4
with 75000 miles on it.....
Turbogst
Car: 04 Pathfinder SE 4x4, 10 Acura TL AWD, 08 Zo6
I always run Mobile 1 and a oem oil filter you can buy them by the box at your dealership
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
I run Mobil 1 Synthetic in all my cars.
cbaccam23
Yea, they had a deal for 5 quarts of mobil 1 synthetic and a mobil 1 filter for $30, but they were out of the 5w-30 so I got the max life sytnthetic blend.
rlp
Car: 03 QX4
Hey guys, let me ask you something. I have heard the putting Mobil 1/ Synthetics in a vehicle with some miles on it, especially over 20000 or so can be a bad thing and that to do so at 60-70-80k not a good idea as can loosen/soften seals and the like and result in leaks and consumption through using or burning oil. In other words; need to use Mobil 1 from the start and you are good to go but at any kind of real miles not a good idea usually.
Any experience with starting to use at 70+?
Thanks.
buckeye3d
Car: 2002 Infiniti QX4
I just switched from conventional oil to Mobil 1 synthetic at 85K miles on my new to me 02 QX4. No leaks. No problems.
rlp
Car: 03 QX4
ThankS!!!!!!!!! Good to know!
Buzzman
rlp wrote:Hey guys, let me ask you something. I have heard the putting Mobil 1/ Synthetics in a vehicle with some miles on it, especially over 20000 or so can be a bad thing and that to do so at 60-70-80k not a good idea as can loosen/soften seals and the like and result in leaks and consumption through using or burning oil. In other words; need to use Mobil 1 from the start and you are good to go but at any kind of real miles not a good idea usually.
Yea, that's a bit of an old wives tale.I switched to Mobil 1 when I bought my Pathfinder. It had 43,000 Kms on it at the time. No leaks, no problems since.What is more important is that once you switch over, stay with synthetic.It's not a good idea to switch back and forth between dino oil and synthetic, like some people do.Stay with one or the other.
rlp
Car: 03 QX4
Thanks Buzzman!!
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
I run Eneos, a Japanese synthetic oil higher grade than mobil 1 (mobil 1 is fine but the price on Eneos is good for me) and a OEM filter even though once I run out of my made in japan oem filters (new ones are made in China for the vq35) I'm switching to something else.
I've switched from regular to synthetic in like 5 cars at higher mileage and have never had a problem.
